Just Sharing This 0.01-2000MHz 2Ghz 32dB DC LNA Broadband RF Low Noise Amplifier Module HF UHF VHF
Might be useful to someone as I found it whilst wandering around another forum:
0.01-2000MHz 2Ghz 32dB DC LNA Broadband RF Low Noise Amplifier Module HF UHF VHF | eBay. - but not for me at present, as this needs to be mounted somewhere near the antennas and can have a local 12V power feed, because I need a line-powered amp well away from the house (unless someone can point me to a good means of extracting the line voltage locally near the amp without materially affecting the signal strength (hint - ideas please?)
Of course, needs a Faraday cage enclosure, connectors and so on. as I would not want this unit spraying emissions "everywhere".
Also, at the bottom of the page, some other similar units with same/slightly different design design/performance characteristics.
