12 304 h on astra 28 e - which satellite and beam?
4wd
Getting the picture
5 W, 9-13-19-28 E
West coast Norway 1.2m, daytime
12168V 27500 8PSK 2/3 14 dB
12363V 27500 8PSK 2/3 12 dB
Nalleman
Motala Sweden
Sweden
From all recently mentioned frequencies I have only 2 receivable namely 12168V and 12129V . Do not forget that during the day signal levels can change a lot, especially if we speak about fringe reception areas. The daily changes of signal level can be up to 2dB.
Can't you get 12382 H? Of 12129 V, 12168 V, 12363 V and 12382 H 12382 is the strongest at my place.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
My antenna is pointed at 28,5*, which is Astra 2E, therefore signals from Astra 2F are not so strong (12382H is on Astra 2F).
lovinthetelly
Sky+HD, Wavefrontier T90 with 16 quad/octo LNBs receiving 42E/39E/33E/28E/26E/23E/19E/16E/13E/10E/9E/7E/5E/3E/1.9E/1W/5W/12.5W through 3 EMPCentuari 16-way DiSEqCs to TBS6522, Octagon SF8008 & Edision Primo IP S2.
90cm for 7W/15W; 1.2m CM in storage.
Thanks for all the replies - keep an eye on STV HD.
ocean04
Vaasa
Western Finland (63N 22E)
12129V and 12168V are 100% 2E UK, currently 7.2db and 7.0db (both flysat and lyngsat are wrong)
12382H is 2F UK 7.0db
12363V no lock (likely 2F UK)
Terryl
Custom built PC
Try satbeams.com, you can zoom into your location in the foot print.
And unless your using a lab calibrated receiver, antenna, LNB and a known loss on the coax, then all readings will be different from a web site like the ones you mentioned.
