For Sale 2.4m Prime Focus Fortec Dish with Stand & Pallet base
s-band
Essex
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
I have same and have added a bolt through the pallet, attached a plate and fixed the stand to it, can now turn east or west easily.
Final call. For good signal levels from Mars and beyond Tin Dish (almost) DX on X band
I couldn't, too many here already, but I would be interested in your Xband feed and LNBs (modification or bought/purloined as such), if you have time to write something.
s-band
Essex
If I had a concrete area I'd like to try that. On grass it's not so easy (and the wheels sink in winter).
Will do when I get a mo. It's a home made 1st stage LNA followed by Miteq 2nd (both at feed) and Ebay bits for filter & 3rd stage amp, junk box mixer/LPF/IF amp. Gilat Ka LNB LO (9GHz) with ext ref. Feed cobbled together from plumbing bits. I change filter and feed between 7.5GHz milsat and 8.4GHz DSN.
s-band
Essex
Sold, pending collection. Thanks. Please close.
I'll leave it here until it's gone. If you could posts again when that's happened we'll do the honours.
s-band
Essex
It's gone and already re-built by its new owner for use on X band.
Thanks.
