26E (Badr-7)
Kypros_Pambou
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
did you try with bigger dish
Is It confirmed that NWA Is functional
Yes i try and with 3.4m but no luck .... Personally i don't know if the beam is functional because i can't receive it...
mar-val
mar-val
Slovakia,Zilina
The MBC TP is stronger today, I have 6,9db on PF 115cm dish...^_^
abece
abece
1.5m 30w<=>60e, Inverto Pro Single Universal LNB, 0.2dB, C120 flange.
1.10m 60e,55e,45e,42e,39e
1.30m 53e-52e, Inverto Black Ultra.
1.15m 36e,31e,28e,26e,23e,19e,16e,13e,9e,5e
0,90m 4w,1w
1.0m 27w
TM 5402
Latvija
cold weather helps, 1.5m dish i get 58%
11270 V 27500-5/6
P
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
11270 V 27500-5/6
I don't know the reason, but + 7% in Milan, Italy with 150 cm
bye
RimaNTSS
RimaNTSS
Some SAT-related hardware.
N-E from Riga
cold weather helps
Only SAT-hobbyist can be happy when cold weather arrives! Welcome to the forum. Do not forget to show some pictures of your installation, from your info I see that you have enough equipment.
Kypros_Pambou
Kypros_Pambou
Greek Cyprus
During early morning hours i have increase of 0.2 dB signal
abece
abece
0,90m 4w,1w
1.0m 27w
TM 5402
Latvija
today nice shining day up to +2, signal almost the same -1%
H
humaxboy1
Laminas 120 cm 75°E-45°W
ClarkTech Diseqc HH390
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
Even in Slovenia the signal on 11270 V is great at the moment..my solo2 is showing 9.5 db
P
pitussat
dishes: CM 3m SMC,-Prodelin 3m SMC old version ,Prodelin 1183 1,80m SMC, Fibo 1,2m,
receivers;>30 different tyupes.+ TBS5925/6925 ETC
Instruments: HP 8563e, tek 491bp , Rover MC16HD, Promax premium3,Unaohm 507a etc etc
belluno,, Italy
Testing Channel Master 3m--> 11270V 26°, LOCATION 46,21°N --MER 13,8dB 12303h 9,1dB
M
Marschall54
Sattelite receiver golden interstart germany
11010 v 27500 3/4
- RTV (ghana)
- PAS DAN
- KENT
- HSM
- ADINKRA
- RUSSIA TODAY ENGLISH
- I9ET
wave frontier antenna t90 antenna
M
Marschall54
11270 v 27500 5/6
- mbc
- mbc drama
- mbc 3
- mbc test 2
- mbc test
- mbc bollywood
- mbc 2
- mbc action
- mbc max
- mbc 4
dreamsat1
dreamsat1
germany
11230 H 27500 5/6 Badr 7 Mena " Saudi Broadcasting Authority " with 3,7m
stel883_
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18" Superjack 3618, Moteck Vbox2, IBU Quad" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single" "Amiko SHD-8360, Edision Primo IP S2, Axas E4HD Combo, Edision OS Mini 4k" "Tivusat Gold Card - Oscam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Gibertini OP100L, Southern Peloponnese
stephan94
stephan94
1.20 Channel master ( Paris)and 1200 Laminas ( Bavaria) KU and C Band
Openbox SX6 and S3 Mini, Dr HD 15, Octagon SF 4008 and Octagon SX88and SX8 HD One, TBS 6983
Bavaria and Paris
currently the reception of Badr-7 NW Africa Beam is exceptional
from the north of Bavaria.
With only a 1.20m antenna I managed to lock the transponder 10970 V 27500
stel883_
stel883_
Vátika, Greece
