31.5W (Intelsat 25)
Tururu
Assembled with recycled parts
Recycled as the owner.
Data from Hylas 1 at 33.5°W not on 31.5°W.
Incidentally, it is Hylas1 to 33.5 ° W.
Last night did not remember, did not have the tp in relation tuner and look for it manually as shown.
Remember to leave a note on the data that have to 30'5ºW, this time not forgotten.
Cierto, es de Hylas1 a 33'5°W.
Anoche no lo recorde, no tenia el tp en la relacion del sintonizador y lo busque manualmente como se ve.
Olvide dejar una nota en los datos que tengo de 30'5ºW, esta vez no lo olvido.
Hylast1 at 33'5°W.....11-3-2015.
Hylast1 at 33'5°W.....8-6-2015
PS: Good fishing/Buena pescas.
I can still get ORTM transponders here with the 1.5m but they are on the edge.
gafsa
180 c/ku band
tunisia
ortm
tm2
A strong signal 72%
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
These are my values 1h ago on Crazyscan using the TT S2-1600:
12284V 7.4-7.6dB
12340V 9.1-9.2dB
12344V 9.8-9.9dB
Here in Germany they can be received even with 80cm these days although they were much weakersome months ago.
MBrincat
1.2m motorized dish, VBOXII positioner, Titanium LNB 0.2dbs,
Dreambox 800HD
Malta
Yes stronger signals now from Malta
12284 V 2200 2/3 (DVB-S2 – QPSK) IS-25 West Africa… (Cherifla TV) 9db (56%)
12340 V 2121 7/8 (DVB-S) IS-25 West Africa… (ORTM Mali) 10.5db (66%)
12344 V 2121 7/8 (DVB-S) IS-25 West Africa… (TM2 ORTM 2) 11b (69%)
pride21
Sandown Isle of Wight
hi all after adjusting my mount i got 12283V 69%,12341V 77% and 12344V 79% i have not seen the ortm channels for a very long time. found out my post has moved nearly 1 degree out of plum,i guess the pole which is set in three foot of concrete has moved over months of strong winds and saturated garden which is like a sponge.
Amazingly I can get 12284 V 2200 2/3 (DVB-S2 – QPSK) IS-25 West Africa… (Cherifla TV) 36% Quality with the TM6902HD + 100cm nothing on the other 2 frequencies,
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Can receive the 3 channels with a 1m dish here. Signal increased quite well.
Had a go at this bird myself with the Channel Master 1.8 and Inverto Black Ultra LNB with its own feedhorn, got all three with good lock near Uttoxeter. Infact the ORTM channles are stronger than CheriflaP1010001.JPG P1010002.JPG P1010003.JPG
100cm Gibby + Inverto Black Ultra + TM5502HD
TM2 showing Fiorentina v Spurs poor signal with this transponder on my 100cm this evening.
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Satellite reception from Cyprus (3.4m) - Cloudy weather conditions
Very strange the weakest transponder here Cherifla tv 12284 V 2200 is the most stable of all 3 transponders TM2 & ORTM are much stronger but are breaking up on my 100cm set up,
That is no surprise to me when you look at the footprint.
nelson_b
Contributor
Yes -- same for me - Cherifla tv only needs around half the signal strength of the other two to hold a lock .
good result for you getting them on 100cm :) .... i,v had them on 1.2 c.m. here in the north west in the past, in very good weather.
i.m currently able to pick them up on 1.8 c.m. ok ... but TM2 & ORTM weaken in the evenings though, sometimes to the point of breakup.
i agree its remarkable that they can be seen at all in the uk :cool:
Cherifla tv now @ 75% Signal Quality nothing on the other 2 transponders here ?
Post #75 above was with the TM5502HD + 100cm Gibertini still 75% Signal Quality
Below 88cm + TM5302HD
I have never been able to get Intelsat 25 with my 88cm before so what is happening is there another footprint from 31.5 west ?
blademedia
Sky
Time of year harder to lock later on for some reason only getting the same tp at the moment will check later for others.
s-band
Essex
I'd never looked there before. I can only get 12284MHz, the other 2 are about 6dB down. The other humps are from 30W one of which will degrade 12284 a bit. Using a 1.5 PF but it may not be aligned precisely.
Edit:
From dx qwer's site Satellites Community - 31.5?W Intelsat 25
I can just see the signal at 12585 that Feedsat mentions there at about 2dB over noise on Crazyscan
Anonymous_1
Wow, good signal today, it was the opposite few days ago,Cherifa signal was weak
Now:
27th of August:
Kypros_Pambou
Greek Cyprus
Also from Cyprus but with high air temperature (36 deg.C)
