51.5E Belintersat 1
Laser
I guess time is getting close now and we will see this satellite with actual in service channels .....
I can't imagine what they'll be transmitting on this satellite. At this rate, we'll have more satellites located 0.5 degrees from each other than channels.
pontiend
Contibruter
south yorkshire
Bad weather here plus my dish has moved a bit.
This seems to be coming from here though.
OOPs I have posted this before.:)
TBS6983 100cm Dish.
puteez
Octagon SF4008- 90e-0.8w
Ukraine
11215 h 20479 dvbs2 32apsk - 7 db
11254 h 1572 dvbs2 qpsk -14 db
adonis1
I' m getting 11245 Η 6991 data ? at 10.6 db
Belintersat countdown is now 1 day 3 hours
Lets hope they have some interesting stuff fta :D
Belarusian propaganda?
Any sign of life on Belintersat yet?? Im away from home getting wet in Shropshire so I cant have a look!
I have scanned a couple of times & checked the satellite finder on the TM5302HD with my 88cm dish 10.7 to 11.7 no activity from 51.5 east only found a new data transponder @ 52 east 11246 H 6990 while doing a scan @ 51.5 east,
Thought I had found the 1st active transponder for Belintersat but when I entered the same transponder @ 52 east the signal bars went up slightly.
Jamie A
What ranges does this satellite use?
I see two data signals
11214 H 20480
11245 H 6991
Are these from this satellite as per Flysat?
Archive4
Not sure if relevant or not, but I seem to be getting sound and picture disruption on ad sport 1 on 52 E , all others seem ok at the moment ( I can only see the MENA beam from here )
Not sure if I will be able to see 51.5 E or not, but trying a blindscan on 52 as 51.5 is not in the stb´s sat list so cannot stop there!
Orbitalzone_Delta
Multifeed & motorised
Istanbul
Belintersat countdown has been removed an hour or so ago. Any delay or postponment for commercial use??
Главная
Belarus is 3 hours ahead of Greenwich Mean Time so I will have another scan at 9pm midnight in Belarus
Nothing here so far
Laser
Yes. Checked as well. All very quiet. Website doesn't show any delays. ...
Orbitalzone_Delta
Istanbul
According to a news item from Belarusian Telegraph Agency back in February, ground control facility in Belarus will be officially opened on April 12th. So, we can expect some commercial activity or at least a promo channel later on, today.
