60E Intelsat 33e
Intelsat 904 left 60.0°E on 3 March, and will arrive at 45.0°E on 18 March.
12066 V 3330 3/4
LIFE78
(14 dB here)
The 11077 V changed parameters... SR: 8332 Fec: 2/3 Mod: DVB-S2/16APSK PLS: Root - 218997
11077 V,8333,2/3,Dvb-S2/16APSK,CCM,stream:Single,code PLS:218997,provider-NURTS Digital as at 45.0E.
MCelliotG
Thessaloniki, Greece
So, they used the same parameters as 45E with the exception that they use 16APSK? I wonder if SF4008 will be able to pull this off...
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
some dumbo has designed this satellite's footprints !! :-Axechase
4Himdj
1.2 Laminas Dish
Rome
:-funbounce only with tuner B
MCelliotG
Thank you! So this is quite interesting, should the tuners be the same, but only the second supports 16APSK on DVB-S?
4Himdj
1.2 Laminas Dish
Rome
well... I dont' know
this is test reception with tuner A (no channel scanned)
you have pm:)
MCelliotG
Flysat reports that TVC started in HD on 12074 V DVB-S2/8PSK 4150 5/6. I don't have any signal on it, can anyone receive it?
blademedia
Sky
Signal level has improved here on Life78, overcast and getting 14db with a 1.2 dish
The Bulgarian operator NRTS Digital distribution platform once again made changes of some parameters at the multiplex on satellite Intelsat 33e. Packet switched from 16APSK on lower modulation modulation 8PSK. The FEC has been increased from 2/3 to 5/6 and symbol rate increased from 8000 ksymb/s on 8331.
Multiplex works still in the mode of multistream and for receiving a package of free Bulgarian stations is required or set-top box DVB PC card that supports this mode.
Even after changing the parameters remains cast of multiplex the same. In addition to public programs, and BNT BNT1 BNT2 HD at SD resolution here and broadcast programs of private broadcasters like CTV, BG on AIR and Nova TV. All are broadcast in MPEG-4/h.264 and FTA.
the new technical parameters-NURTS Digital platform:
• Intelsat 33e (60 ° E) freq 11.078 GHz, pol. V, SR 8331, FEC, 5/6, DVB-S2/8PSK/stream 3, FTA
programs:
-bTV
-BNT1
-BNT2
-BNT HD (at SD)
-BG on AIR
-Nova TV Bulgaria
mister_rf
Redline TS3000HD
motorized 120 antenna
fixed dish 150
Invacom LNB
Bucharest, Romania
New technical parameters for Prima TV and Kiss TV on the Intelsat 33e (60 ° E)
Beam: K29V/K29H
Freq: 11.672 GHz
Pol: H
SR: 4960 ksps
FEC 7/8
DVB-S/QPSK
Spot beam 29 is easy here, 11672 H gives over 14 dB.
Should be easy in UK & Ireland as well.
blademedia
Sky
Beam: K29V/K29H
Freq: 11.672 GHz
Pol: H
SR: 4960 ksps
FEC 7/8
DVB-S/QPSK
Thanks for the information, strong signal with 1,2 dish, set top box maxed out.
mister_rf
Redline TS3000HD
fixed dish 150
Invacom LNB
Bucharest, Romania
Here are the two photos, for a comparison of signal level/quality, which I have managed to obtain on a small motorized 1.2m antenna.
Fist image the old Intelsat IS-12
and on the second the new Intelsat IS-33e.
The new signal strength is slightly lower compared to the old one.
puteez
Octagon SF4008- 90e-0.8w
Ukraine
What happened with 11078 V 8331 5/6 ??
mar-val
Slovakia,Zilina
11077 V 7405 3/4 DVBS empty atm.
