Help Required Adding a custom bouquet on my vu+ duo2 receiver
daro2096
No setup at present
Consett, Durham
How do you do this in Open VIX? I have pressed the down key and pressed the blue button and up pops Favourites (TV) and Last Scanned. I press menu and highlight and press add bouquet and I have typed in the name of the custom bouquet folder I want to create in this case Favourites (HD) but I can't see how to save it.
Help please? What am I doing wrong?
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
green key?
daro2096
No setup at present
Consett, Durham
It is okay I have worked it out. You got to press the green button when you are done typing out the name of the folder.
Mickha
North West
You can also use Enigma 2 tools, like dreamboxedit, which allows you to download your receivers channel list, onto your PC, add new folders, edit channels, then return the modified channel list back to your receiver.
