Amos 7 (was Asiasat 8) 4W
VodzigorLans
Setup is down atm
RU, Saint Petersburg
New stuff is here today... Bad affect to French radio package...
VodzigorLans
Setup is down atm
Now Test tp is blocking Fransat package.:mad:
Amos 7 4°W), freq. 12,288 GHz, pol. H, SR 30000, FEC 2/3, DVB-S2/8PSK, CA Videoguard
• Amos 7 (4°W), freq. 12,348 GHz, pol. H, SR 30000, FEC 7/8, DVB-S/QPSK, CA Videoguard
4 west is slowly becoming a vanishing constellation here in the East of England with a 100cm dish :( total demise will become apparent when Amos-2 shuts down.
VodzigorLans
Setup is down atm
Signal is much lower than Amos3 so i guess it is CEE beam or it is just low during double transmission?...
MCelliotG
Thessaloniki, Greece
Both coming at about 14.5db on my system! Not the strongest I expected tbh...
Στάλθηκε από το LG G3 μου μέσω tapatalk.
Signal there but way below lock - 5db and 4db respectively.
12315 H 15000 no signals here for a couple of days now looks like it is on the same beam as 12287 H 30000 & 12348 H 30000 no lock here now on any of these.
12315H is actually one of the stronger transponders on 4W - 7.3dB.
Amos 2 ended the distribution of several multiplexes
Israeli satellite operator Spacecom ended the distribution of a series of multiplexes and programs on the old satellite, Amos 2, which is parked on position4 ° W. A number of programs are now broadcast on satellites Amos 3 and Amos 7, which are located at the same position.
SPACECOM ceased operation of these multiplexes:
• freq. 10.722 GHz, pol. H, SR 27500, FEC 3/4, DVB-S/QPSK (1)
• freq. 10.759 GHz, pol. H, SR 30000, FEC 3/4, DVB-S/QPSK (2)
• freq. 10.806 GHz, pol. H, SR 30000, FEC 3/4, DVB-S/QPSK (3)
• freq. 10.842 GHz, pol. H, SR 30000, FEC 7/8, DVB-S/QPSK (4)
While the first mux is terminated without compensation, the packet broadcast originally on flicker. 10.759 GHz is now located on freq. GHz mux 11.175 Third (ex 10.806 GHz) will find now leads to a stroke. 11.140 GHz and the latest mux (ex 10.842 GHz) is currently available on freq. GHz 12.315.
new parameters: muxů
• freq. 11.175 GHz, pol. H, SR 30000, FEC 3/4, DVB-S/QPSK (2)
• freq. 11.140 GHz, pol. H, SR 30000, FEC 3/4, DVB-S/QPSK (3)
• freq. 12.315 GHz, pol. H, SR 15000, FEC 7/8, DVB-S/QPSK (4)
At the orbital position 4 ° W have left no Ukrainian commercial station 1 + 1 Media Group. The station is designed to appear on the new satellite Amos 6. After the explosion on the Baikonur SpaceX and the loss of the planned satellite broadcaster decided to use satellite capacity for competitive operator SES (Astra) to the satellite Astra 4A (4.8 ° E).
Any idea of what Amos 2 will be used for?
tempo
47.5N, 42.2E / Russia
Somewhere in sat news I have read that Amos2 will be moved to graveyard orbit
Only FTA channel here now is the test on Amos-3 10723 V 30000 all the other transponders with FTA tv not received here anymore with a 100cm dish.
VodzigorLans
Setup is down atm
It seems like CTV feeds are moved to Amos7 as well... 12375 H 4800 /3200 8psk sr, was able to lock it earlier but not anymore... i guess CEE beam?... because those feeds were stronger at Amos3 here...
Coviello
Potenza (Italy)
Prodelin 11ft (335 cm)
Windows 2000 XP
Southern Italy
I receive 11083H from Middle-East beam of Amos 7 (signal level 4.7 dB on F15-HD receiver) in Southern Italy (Potenza, Basilicata) with my 3.4m Prodelin antenna.
Coviello
Archive-8
I am locking transponders:-
10723 V 30000 9.8 db
10889 V 30000 8.8 db
10926 V 30000 8.9 db
11568 H 15000 13.1 db
10807 V 30000 8.5 db
10843 V 30000 8.5 db
Using my Gibertini 1.5, ice crypt lnb, and Dr Hd D15.
South west uk.
nelson_b
Contributor
Not a satellite i,v visited in a long while ..... Just testing the limits of the 2.4 c.m. quite surprised to lock this here in north west uk .....
nelson_b
Contributor
11061 H
4500 1/2 METV (Middle East TV) also locking (4.2 db) and watchable without breakup since late last night ....
11067 H 3000 2/3 Knesset Channel is showing between .0 and 2.0 db on the F15 but no lock as yet :(
Very interesting and surprising results. I get light flickers of signal but really nothing to speak of. Could just be noise!
Just shows how much bigger the 2.4m dish is compared to 1.8m...
WaferSat
Laminas OFC-1200P, 30w-46e
Southern Finland near Helsinki
321 channels found today, I believe ~280 channels was found about a month ago...
