Advice Needed Arabsat
Gladstones55
Gladstones55
Astra 2 60 cm fixed
Edinburgh
Want to get MBC 1,2,3 & Max on arabsat badar4
Do they broadcast in English with Arabic subs
Any fta sport on arabsat ? Is it hard to get on 1 meter Technomate dish
Location near Edinburgh
Appreciate any advice thank you
OP Gibertini 100 XP+ Inverto Black Ultra 0.2
(50 east to 34.5 west)
TM6902HD (A/B switch) Octagon SX88+Optima
Raven 88cm Mesh Dish + TM-1 0.1
Octagon SX88+ (A/B switch) Edision S2
45cm dish V8 Golden 28E FreeSat Quad Lnb
Virgin Media FreeSat
Gladstones55
Gladstones55
Astra 2 60 cm fixed
Edinburgh
Possible to get 7 west on 80 cm perforated dish
MBC broadcast there
Tout Rond Bon Oeuf
Gladstones55
Gladstones55
Astra 2 60 cm fixed
Edinburgh
Ok
What about 7 East
Gladstones55
Gladstones55
Astra 2 60 cm fixed
Edinburgh
Ok thank you
Skybox F3
You should get some tp's off Badr 4 - I used to get them quite easily on an 80cm dish in Galashiels. Ive not had much luck with them in recent years though. We used to get the MBC frequency on the hypothetical MBC beam too which was nice. You have virtually no hope of any of the others Badr's this far north on any sensible sized dish.
SatSearcher
SatSearcher
1m orbital dish with 0.1 Technomate LNB. TBS 6903 & TBS 5925 Card & Octagon SF4008. 39E-55W.
West Yorkshire
There is an MBC package on Hotbird 13E, 11258H, but you'll need an official card for this, or there are a couple of channels dotted around on Eutelsat 21B (21.6E) using BISS encryption, which are easy enough to get.
Gladstones55
Gladstones55
Astra 2 60 cm fixed
Edinburgh
Anyone knows how to subscribe to to MBC at 13E
How to get a key to open BISS encryption
Can we legally subscribe
Skybox F3
MBC 13E subs is probably local contacts in the service area only
BISS keys are easily found online, but be advised the 21.5E satellite is pretty lousy strength in Scotland and you will struggle with it on an 80cm dish.
Gladstones55
Gladstones55
Astra 2 60 cm fixed
Edinburgh
Better of with sky then
Thanks for help
