Astra 2E: General Discussion (Post-Testing)
Here you go.
Nice new Topic all ready and waiting for the end of Testing.
Best intelligence to date suggests completion of Testing this week with transfer to 28.2.e commencing this coming weekend at a rate of somewhere between 0.5 and 0.8 deg/day.
(Thanks to Member solly)
buckshee
15.3 degrees difference, that makes it 19 - 30 days to get there. Is that correct Tivu ?
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
2F took about 14 days?
Jester87
Famaval 2.4m Sky On-Demand
Republic of Cyprus
In Ka-band the transponders are 4. Two 580 MHz, one 480 MHz and one 240 MHz from interconnected in Ku-band with the beam Middle East....
What chance of ANY coverage of Cyprus on any band from the new 2E satellite?
Viktor.
Viktor.
Unknown. You can forget the PSB channels on the UK spotbeam though. No chance of those unless something very weird happens.
If you get the 2F European beam you have a reasonable chance of whatever ends up on the 2E Euro beam..
Viktor.
the pe beam will be receiver more then 3 ,0
here in Israel we got two tp 2f 12304h 12266h
weak signal 4 hour and it gone
Astra 2F -- Astra 2E -- events
2012-09-28 -- 2013-09-29 -- Launch
2012-10-10 -- 2013-10-11 -- First signals at 43.5 East
2012-11-09 -- 2013-11-?? -- Leaving 43.5 East
2012-11-21 -- 2013-??-?? -- First signals at 28.2 East
That's about the size of it and it's a safe bet she'll be on her way soon.
But it still depends upon the satisfactory completion of the entire programme, although I can't imagine it is any more (or less!) onerous and extensive than before.
DishDick
Gran Canaria
I didn´t realise 2G was going up next year, Oh no, more speculation. Shall I start it off. No coverage with 3m dish 1cm off the coast of UK! Its getting like all the Apple speculation in the press. After 2G, what is the next scheduled update to 28.2 degrees?
2H 2K & 2L should be ordered sometime about summer 2025 :D
So, no 2B or not 2B jokes then?
DishDick
Gran Canaria
Ok, cheers. I am thinking of geting a new large dish as internet is terrible here. Obviously I wanted to see what 2E had in store for us, now I have to wait for 2G. Still it will give me a good idea of what I can then get for the next 10 years or so. Internet speeds here should then be in to double figures (currently approx 0.39mb, yes 0 point 39!!).
Cripes: I thought my 0.72 was bad :eek:
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Any idea why SES don't use the letter J in their satellite names? I suppose "I" can be confused with a 1 but why not use J?
if astra found solar panel problem will be order more satellite
2b was back to 19.2e if astra 2e was crash
it plan switch 2c satellite
for now no need to worry 1n original be come to 19.2e
kevjs
28.2/5'E Zone 1 Mini Dish connected to DVB-S Tuner into TVHeadend/XBMC with a 60cm dish bought out for Astra 1 on Grand Prix weekends. With Android XBMC box in the kitchen too.
South Notts.
The lowercase i and j can look very similar in lots of fonts and apparently are avoided in astronomy (presumably only for non "names" stuff). The letters j, u, and, w don't exist in Latin either.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
So it is finally on it's way and from what others have previously said it should arrive in approx 11 days time, say Thursday 28th November. Given that date, and again from what I have understood from our various threads/posts, this should mean that transfers from 1n to 2e can, and should, be seen before Christmas. Have I got that right?
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
Well, no confirmed reports of it moving just yet, just an odd TLE suggesting it is going east (ie the wrong way).
As for when things will finally transfer over, no one knows for sure yet, but it probably won't be all in one go. There may be a few brief tests at 28E first before any big switch overs.
