Audio problems with bbc hd
Rusty Dish
Comag sl1000hd 2ci
Triax 60 cm 4 LNB
16E/13E/19.2E/28.2E
Dartford Kent
Apologies if this has been covered elsewhere but.....
When viewing BBC HD the sound has more music than speech ????
its like the balance has been adjusted in favour of the music, its just
BBC HD and none of the other freesat HD chanels are affected (luxe tv and
some other german HD chanels are fine)
any ideas...
How are you getting the sound?
Direct from TV speakers?
Via RCA connection from Box to Hi-Fi?
From Home Cinema?
Are the particular audio tracks with issues in Dolby Digital?
Are you Audio settings appropriate for the means you are using to project the sound? (Equalization, Dolby, etc.)
Rusty Dish
Comag sl1000hd 2ci
Triax 60 cm 4 LNB
16E/13E/19.2E/28.2E
Dartford Kent
Hi Yes the sound is straight to tv speakers, its odd that only this
chanel is affected.
Rusty Dish
Comag sl1000hd 2ci
Triax 60 cm 4 LNB
16E/13E/19.2E/28.2E
Dartford Kent
ALL sorted, i had a quick fiddle with the comag audio settings
and its now loud and clear many thanks
