Bearings and housing for the classic precision mount
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Good afternoon from an overcast Mullion Cove Cornwall : )
Does anyone of you most Knowledgeable gentlemen have, or know where to purchase bearings with the casing for the classic Precision mount ?
I have two mounts, the one that I purchased from Moonbase is fine.
The other my original works fine, but there looks to be rust in the top part of the bearing as well as its case.
I note that though both mounts look the same, the allen key size to hold the main through bolt on the bearing is larger on one ?
Both the bolts appear the same size as does the bearing housing.
God Bless Spiff
Pictures maybe?
Also, is there a maker's name &/or part number on the bearing?
God Bless Spiff
Spiff,
The original bearings used by Precision are ASAHI FT203 bearings (AMI) with a 16mm bore. The FT203 refers to the ASAHI housing and the bearing insert is model 203PR-C. You may find that these are quite dificult to source.
For Precision polar mount renovations I have used RHP SFT16 bearings that are readily available from quite a few UK based suppliers. These come with the equivalent 16mm bore. In addition, the hole spacings on the bearing flange type housing align with the fixing holes on the Precision polar mount.
The allen key for the bearing shaft bolts is M14 across the flats for the M16 bolts that are usually fitted.
If you check back through some of my Precision refurbishment topics or for sale topics there will be pictures available.
For convenience, I have attached some pictures of the original Precision bearings and the replacements.
If you are replacing the bearings it may be a good opportunity to check if the bearing shaft bolts need replacement?
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Thank you to Moonbase and jeallen01,
Great news that bearings with a housing are available that will fit : )
My installation is like a much loved car to me, I am always updating : )
I have just installed two extra cameras, and small spirit levels to watch the Elevation as the actuators move the dishes up and down.
The red spirit level is temporary, another single one is on order.
There are two other cameras to check the East West settings.
One of them requires replacing as it will not focus in close, hence the fussy picture : )
They are all USB cameras via USB or cat5 links..
Thank you again God Bless Spiff
