BEIN PACKAGE
Journey
drx 890
Apologies for repeating previous comment but would love to know if this could be gained in the UK and what size dish would actually do the job ? Sadly i am not sure if we have anyone with 3.7m+ dishes in the UK to check, or do we ???
@nelson_b has a 3m but he's way oop north... I think this satellite is a no-go. Probably easier to find someone in the coverage age to host a Slingbox (or similar) for you.
nelson_b
Contributor
The 3 m i have is only setup for C band -- an initial test a month or so back for k/u performance on it , revealed it to be not much better than the 1.8 c.m. :( which shows nothing here for the channels you are after.
nick theo
sat hobby
cyprus
Bein 11 12 13 etc still working on 25.5E but all my customers here in Cyprus are on 7W. Going to be a busy week realigning dishes ...
Hi Zorba,
What size dish is required from Cyprus to receive 25.5E?
Probably receivable on a Sky mini-dish there!
nick theo
sat hobby
cyprus
According to the footprint posted by skomedal ( http://www.flysat.com/e25b-beam.php ) for Eutelsat 25B Ku-band (MENA), Cyprus receives between 50 dBW (on the east) and 49 dBW in the center of the island through to the west.
I have been told I need 1m dish - although if the footprint is accurate, a 75/80 cm dish should in theory be ok .
I will have ago re-positioning my dish (75/80) and will post to let future users know.
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
We are in the 49dBW zone and is coming in at about 9db on a 60cm dish.
woborny
wolzy67
bigsat 60cm bigsat fta. Hispasat
1.4 p/f quad invacom. Astra 28
80cm offset nilesat
Gi genuis,gi 8120,gi genius on open atv ,en2
torreiveija Spain
Hi buckshee on previous thread when we had prob with TV guide we rebooted. Can't seem o get this to work on 25.5 have you had similar problem.
Regards
solomons
Nilesat 7west
uganda
Ion English commentary is back on all 3pm kick offs. It seems the move to Eshail is working out well for bein.
buckshee
Regards
I found that if the satellite box is switched "ON" and tuned to a Bein channel, if you then disconnect the power (remove the power cable from the back of receiver) it will then reset the time, once reconnected. Done it only yesterday, after a power cut. Will not work however when tuned to 28.2E.Hope this helps ;)
wolzy67
80cm offset nilesat
torreiveija Spain
wolzy67
80cm offset nilesat
torreiveija Spain
yes I think I tried that on different receivers realigned quite a few this week and can't get the epg to come on do you leave it in any particular channel .
Regards
buckshee
Regards
I am only speaking about the clock setting. I also have no epg, on 25.5E
wolzy67
80cm offset nilesat
torreiveija Spain
I see if I can find out why and let you know thanks
nick theo
sat hobby
cyprus
Further to the above, with a 1m dish signal strength shown by the Bein Pace receiver as 40% in Nicosia, Cyprus. Obviously the type and quality of the equipment affects reception.
