Advice Needed Blindscan
Pipedream
Sheffield
Looking to buy a new receiver, what would be best for doing blindscans?
stephan94
Bavaria
Since the appearance of Edision OS Nino Pro (no UHD) and Edision OS Mio4K (UHD)
The question is no longer asked .
They are the two best receivers for the blindscan, very fast, find only separate frequencies
of 1MHz, finds Mode and code for multistreams (even PC cards can not as fast), finds a large part (not all) of T2MI.
Read what is written on these two receivers in the forum.
only limitation, does not go below SR1000.
The Octagon SX88+ is an excellent HD Blind Scan receiver with Multi-Stream this is one of the best receivers I have tested in the last 6 months it also has a very sensitive tuner for weak signals this is an essential requirement for feeds.
Manikm909
Small'ish Dish Man
Kent, UK
i have one, no UHD though....i find my SF8008 (4k) just as good as the SX88 for blind scan...i had the OS MIO 4K - but sent it back as i di
i have the SX88 (not 4K), and its great for blind scan. I sent the OS MIO 4K back, as i didnt find the tuner that sensitive. I find the SF8008 just as sensitive as the SX88 but its E2 (and 4K)_
You are replying to threads that are nearly two years old.
Manikm909
Small'ish Dish Man
Kent, UK
