bracket for disecq motor
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
the original motor on the fibo doesnt work, its circuit board inside is fried
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Got some pics of it mate, might be fixable :)
saj1985
Lost...
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
saj1985
Lost...
saj1985
Lost...
got the bracket and lnb from @Trust1
big respect and thanks to @Trust1
actu_8
Technomate TM-600. 1.2 Metre Dish.
Hants/Surrey Border
These are long gone , but I can build one .
Hi - It's an old thread but I'm in the same situation. I have a home-made bracket on my recently bought Fibo but it's off-centre. Would you be able to help with instructions/materials to make a proper replacement?
Post some pictures.
Trust
Nijmegen Netherlands
here some idea's
You should be able to slacken off the u bolt nuts and slide around to the correct position.
actu_8
Hants/Surrey Border
Post some pictures.
As you might see from the photo, it's off centre. One idea is to modify the right hand side bracket so it is the 'mirror image' of the left hand one bracket and use spacers to centre the part that clamps onto the stab mount. Altertively find the relevant part that Trust has used from a motek motor and cut off the sides and bolt them in a similar way to the current parts, again using spacers.
Trust
Maybe you can by drilling new holes for the U-bolts move the poleclamp to the centerline of the dish
actu_8
Hants/Surrey Border
Great idea but I'm not sure there's enough room to drill fresh hole, but maybe a smaller u clamp might do the trick. I'm thinking of trying to get hold of an old AZ-El mount and getting it welded to a steel plate with holes to mount to the dish.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
When it is off centre, but still exactly parallel to what it should be, I see no big problem?
Not even for a motorized setup.
(Though the setting of motor and dish exactly in-line at zero degrees, is a bit more difficult, when you normally would do that with the equal-length checking of left and right side of the dish to the pole (or motor housing).)
If it is exactly parallel, all the motor- and aiming- angles stay the same.
It is a bit hard to see on the picture, though, if the left and right black dish brackets are exactly equal.
greetz,
A33
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@actu_8 PM me if you are interested in getting this original Fibo bracket. It is used but in good condition.
actu_8
Hants/Surrey Border
greetz,
A33
Many thanks. I am very happy to receive this info. I wasn't sure if being off centre would skew the tracking of the arc, especially when a mate said it would. I'm pleased he's wrong. The left and right brackets are identical, thus causing the offset, which I would normally file under 'bad design'. As the motor is using another dish and is set up correctly, I can line up the middle of the clamp pictured to the centre of stab mount pole on and check for the best signal on 1w and take it from there.
Looking at another thread (Fibo 90 feedhorn and fixed Az/El mount), a near-identical version of the bracket is shown so I'm thinking it might be the after-market bracket from Satmeuller.
Thanks again.
actu_8
Hants/Surrey Border
Hi - I can't seem to PM you. Perhaps ypu could PM me and I'll reply. Thanks
