BulgariaSat-1 @ 1.9E
rodscha
Thank you I understand and I was just wondering what king of programmes Bulgaria would rent its satellite to,since Bulgaria has a very small population to fill a whole satellite.
Hence my asking! I ll be waiting
Lexzie
TBS 5925 USB-tuner
The Netherlands
Maybe this will answer it a bit:
Watch this space. I would guess there will be a lot of channels on this satellite as it is a part venture with Bulsatcom which currently use transponders on Hellas Sat 2 at 39 east
EnoSat
enosat.euweb.cz
Slovakia
FEC 3/4 & DVB-S unless stated:- Blind Scan 11700 to 12500 H & V TM5502HD + 100cm dish
Test Carriers observed today:-
12310 H 2640 5/6 S2
12326 H 2600
12333 H 2220 S2
12338 H 1480 S2
12343 H 2220
12348 H 1480 S2
12495 H 2220 5/6 S2
12306 V 2220 S2
12316 V 1910
12319 V 1850 S2
12346 V 9720
12436 V 9260
FlySat BulgariaSat-1 @ 1.9° East
all FAKE , next big bug from Wiliam-1
use LOF 10600 but not use 22 kHz
12310-10600=1710 11460-9750=1710
all data from Eutelsat 3B
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
I think I'm not mistaken if I say many users,if not the majority,from this forum are not interested in TV programs,but the possibility of receiving satellites that are operational;less interested,the better.For these users,rathers dxers, every satellite launched regardless of where it is placed is a technical challenge,and if they succeed,is a reward for the passion they invested.
Exactly. Getting a signal from a fringe reception area or a new satellite is the orgasm of a satellite dxer :) Dxers rarely watch TV because they are busy aligning dishes :)
Spent all day Monday on & off with a few refreshment breaks improving my signals :-biglaugh
s-band
Essex
The really sad people here only look at the beaconso_O - much more interesting than programs.
archive10
What is this "watch TV" thing? I don't understand...
I think it is a new phenomena way over my head ;)
The 850 MHz offset "bug" has happened quite often, from the past I remember several false Badr transponders reported by others.
It may be wrong configuration in receiver, faulty LNB, and also some twin/quad LNB have a sneaky internal L.O. frequency leakage. That's why I prefer single LNB for DX!
I suppose william-1 has already told Flysat to delete these fakes, but we all know Flysat response is a bit... unpredictable!
FlySat BulgariaSat-1 @ 1.9° East now updated :)
Lexzie
TBS 5925 USB-tuner
The Netherlands
Can anybody tell me if and how the test carriers can be received?
s-band
Essex
If they are just carriers they will show up as a circle on Crazyscan's constellation display. In the case of the beacons (which may be carriers or low data rate xPSK), they may show as a furry circle or there may be a hint of a constellation in Crazyscan depending on signal strength. Here are examples: BulgariaSat-1 @ 1.9E and Satellites Community - Beacon(s)
Otherwise, a spectrum analyser is the only easy way:
Yes, they are signals of Telemetry/Beacons (11705,50 V and 12496,50 H)
View attachment 109070 View attachment 109071
Based on the observed test carrier, roughly this should be the frequency plan..
From SE UK on 1.5PF
Note: DRO LNB so centre frequency on plots not accurate
View attachment 109574 View attachment 109575
I'm not sure how set top boxes respond, maybe someone else can say how yours will, if it will.
The way I separated 1.9 from others was to peak the dish on the unwanted and then the wanted so I knew which was which.
I am using 10 east for this exercise:-
With a receiver like the TM5302HD & 5502HD there is a menu called Satellite Finder this shows via a graph the active transponders on a satellite,
Operating in 4 bands 10700 to 11700 H & V
--------------------------11700 to 12500 H & V
Now I can see where there are more active transponders so I will Blind Scan these area's but the receiver will only lock onto 8PSK & QPSK transponders,
Although I can see 16APSK transponders in the graph I cannot lock onto them most of these & 32APSK transponders are data streams.
FlySat Eutelsat 10A @ 10° East
New Blind Scan now shows the new transponders in my data base:-
DSCN2067[1].JPG DSCN2068[1].JPG DSCN2069[1].JPG DSCN2070[1].JPG DSCN2071[1].JPG DSCN2072[1].JPG
Lexzie
TBS 5925 USB-tuner
The Netherlands
Nice.
I wish someone could make something like that for Enigma receivers.
Laser
Be nice to have a Test Card so we can get the exact position locked in.
astrall_91
Bulgaria,Lovech
13-16-19 E 85 cm
Tecatel 120сm 36 E ,GS B211,TRICOLOR TV
Bulgara
On base of unofficial information here in Bulgaria,Bulgariasat will be start of exploatation between 11- 25 September. Information from Bulsatcom forum:
http://forum.bulsat.com/viewtopic.php?p=224574#p224574
kocebs
Bulgaria sat
Germany
We've been waiting for a long time! Will it be this year? :(
