Just Sharing This Channel Master 1.2M Installation/Restoration
Archive-8
Finally I discovered what that thing is for in my garden with the "lines" that seems to spin around in the wind!
Got the drill and brushes out and prepped these parts, removed all the rust etc. Now coating them in some nice anti-rust primer.
It's a lovely shade of Merde don't you agree?
It’s a cobweb antenna :-rofl2
http://www.m0pzt.com/cobweb-aerial/
Still good going :Y
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Still good going :Y
The "G3TXQ" Hexbeam, I know Ant (MW0JZE) who makes/sells those
CH that's for the 2.4m SMC, not the 1.2m. And it does not list bearing size (Well I can't find it anyway :-rofl2)
It was an example of proper CM manuals against the later pretenders. Do you want to be mollycoddled throughout life?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
But none say the bearing size, I've looked at the older copies and later copies.
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
Pipedream
Sheffield
This may or may not be of any use.
  • CM Polar MT.pdf
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
saj1985
Lost...
I paid £50 for it
Cheers, I think you posted that earlier on in this thread. I've "Collected" A few CM manuals now :)
you cant go wrong, did you travel far for it?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
saj1985
Lost...
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Had another look at bearings today, it seems impossible to get any Oilite in a suitable size, and you cannot get the inner sleeves in the right size.
So going to get some 6882 ball bearings (Flanged and sealed, F/RS), drill the mount out to 16mm or press them in with a press.
Save all this faffing around with antiquated sizes etc.
Is it an option to consider mounting a flanged bearing unit top and bottom? The old Precision dish polar mounts used flange bearings top and bottom but I am not sure if you could adapt a channel master polar mount for them?
2 Bolt Flanged Bearings | UCFL Bearings | SFT
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Yeah that's one way of doing it with a few mods, but that will cost a few quid :)
I've ordered some F6882RS bearings, I'll see if I can press them in as the holes are 15.9 on the CM Mount, if not i'll put the mount on a press drill and make them a bit bigger. The bearings are usually undersized rather than oversize, should be <16mm so might be enough to pop in.
archive10
Remind me, was the old Oilites worn out, or why can they not be salvaged?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
When Captain Jack bought the dish the bearings were missing.
They had decided to use it as a fixed dish so binned them I guess.
I bought the dish from Captain Jack, he had some bearings in there but being a metric size they were a bit too small.
archive10
They had decided to use it as a fixed dish so binned them I guess, I bought the dish from Captain Jack.
Ah!
Would it be an option to post a question on one of the US sites to see if they can advise on US suppliers of imperial measures?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Ah!
It's a one off the config they used, the steel insert is a non standard size.
I'd rather use a decent quality ABEC ball race anyway, I'll update the post when the bearings arrive and if it works it's a nice easy solution and will be available easily rather than having to mess around getting imperial parts.
3D print a couple of copies in plastic, and die cast them in a home foundry.
