Just Sharing This Channel Master 1.2M Installation/Restoration
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
Ghostleader
Glasgow,ish!
Suns out tools out!
Drilled a load of holes, got some threaded rod and chemically (resin) set them in to the concrete bases.
Fitted a nut and washer either side so I can adjust for absolute plumbness.
Is that the two concrete fence posts, did they get painted, they look a kind of brown colour in that photo.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
It's 2 concrete fence posts that I nearly threw away when I took them down :)
They are VERY heavy and full of rebar, good job I kept them. Cut them to the size I wanted with a diamond disc on a grinder.
They were brown before, but don't actually mind that colour as they don't seem to stand out much on the ground.
Ghostleader
Glasgow,ish!
They two fence posts have become a great freecycle mate, glad you said how you cut them because I was going to ask that! lol
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Not updated this for a while as I've been having so much fun with this, the dish has been up a few days.
Signals are approx 2-3dB or higher than my gibby 1m. Which is helping me quite a bit on weaker transponders.
Ended up using 4 core 0.75mm Mains flex, was really cheap from the wholesalers and really nice stuff, was rather OCD about the wiring to the VBOX so sleeved it, tinned the ends and colour coded the wires.
Things left to do... Paint the dish, fit a IBU Twin and run some more coax (That's why the actuator wire isn't on the pole) And I might even get a 1.5m Pole to give me a bit more than 46E
Restored Polar Mount, new bearings, all bolts INOX (Stainless)
New "SuperJack" Actuator, I covered this in Lidl Cavity protection spray, it's waxy stuff you use on a car chassis.
Restored LNB arms with Lidl Alloy Wheel Paint, I think they came out very well!
Mount from RimaNTSS, I drilled the concrete and chemically set the bolts, there are 2 nuts and 2 washers to each bolt to help level everything.
Bought a Galv 3" pole from a local sign company for £10, seems it's a standard item used for signs so quite easy to get hold of.
Bit of random pipe I had, just to stop me stepping on the wires!
Tinned and sleeved cable to VBOX-II
New editions, Mutant HD51, VBOX II (Thanks @Captain Jack for the VBOX II) I stripped it down and painted it Black with Lidl Matte Black spray paint,
Also bought a Edision Primo IP S2
Ghostleader
Glasgow,ish!
"Nice".......(Anybody reading the "nice" should do it in their head with the voice of the Jazz guy out of "The fast show" lol)
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I actually did before I read your text in brackets.
Jazz Hands.............
Oh like side to side
Not like the motorised the does the arc as well
Yes, basically side to side. A polar mount is also needed to track the arc, the actuator then moves the dish to what ever orbital position is required.
saj1985
Lost...
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Decided to paint the LNB arms, seems Lidl "Rim Paint" is a perfect match, I did try Aldi Direct to metal Silver Gloss (Non Metalic) but doesn't look as good.
Lidl "Rim Paint" Left - Aldi Metal Paint Right.
Lidl have some "colour lacqer" on sale today for £2.99 is this similar / the same as the "rim paint"?
