Channelmaster 100 dish and ku/cband
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
I've recently received a Channel Master 100 dish with a Cband LNB and I would like to ask what is a CM dish of that size able to catch on Ku/Cband (based in SW Essex)? As in sat range?
Thanks.
Trust
Nijmegen Netherlands
Thats a 0.9 m dish with a Ku lnb not C band
Chr0nik
Grays, Essex
oh I see, due to the size, would it then be useless for cband? it's a CM 3040681-01
Yes, it's waaaay too small. 1.2m is the minimum you'd get anything from C band. That said, the above is a good dish for Ku.
Pick your satellite carefull & you should get some c-band signals - Ive had some success with 20E & 40E on a 1m dish
It's not too small, I have been catching a couple of C band transmissions on 40E with a similar sized - pfa - dish for a while, but only useful if you speak Russian.
It will require modification with a different feed arm clamp for the right LNB, and if you move too far from London the signal drops off like a stone going west (as Cap'n Jack knows), but you should be OK in Brixton.
You might also get an African channel from 37.5 W now I've swung it around.
