Difference in softcam key
majicm
1 Metre dish, Supreme Dark Motor, Inverto Black Ultra Quad LNB, VU+ Uno, TBS 6925 Card
Darwen, UK
Hi guys
What's the difference between softcam keys for certain receivers?
For example, the encryption system starting with I and rhyming with Lerdeto in the generic sofcam.key files have a 32 byte key but for the Clark Tech one it appears to be 16 bytes.
Why is it and is there a way to convert between them?
Also, what's the relevance of the "Slot x" sections in the files?
Thanks ;)
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Forum information is there to be read, you have to alter the standard 60 day search parameters at the bottom of the page to find out what you need. There are 54 pages of information on the subject of encryption some of which will provide your answer, the information is generally old hat now and therefore does not display automatically but is there for you to read if you think you need to
Keys and Key editing | Satellite TV & Digital TV support forums
majicm
Darwen, UK
Thanks man, I did a search but obviously didn't go far back enough :(
Just down the road from you it seems!
Topper
Aye....... I was working at a place on Bog Height Road until end of January :eek:
majicm
Darwen, UK
An interesting area :)
