DM7025+ to Web (justin.tv etc)
SilenZ
80cm Motorised Dish with Invacom 0.3db LNB
Golden Interstar 8005 S Receiver
Dragon Cam
Belfast, Northern Ireland
I've had a look around and can't find a method of streaming from my DM7025+ to the likes of justin.tv, FTA channels ofcourse, and only for my own benefit when I'm at another location.
Justin.tv looks for a capture device. I can stream from my Dreambox via LAN using the webinterface. Is there anyway to capture the stream so it will stream to the likes of justin.tv?
hungary2006
DREAMBOX 7025+
Suomi
SilenZ said:
hmmm, not sure yet. Bcos Justin.tv video format is flv and Dreambox is .m3u which uses VLC, Mplayer to play it. Another way is by trying Bitcontrol Software which can converter .m3u to .wmv meaning that Windows MediaPlayer can play it.
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
SilenZ said:
You'd need to have a decent amount up upload bandwidth.
If all you want to do is watch TV at a remote location, there is no need to do it via justin.tv. Have a look at these threads on doing it with VLC.
http://www.satellites.co.uk/satelli...aming-dm7025-internet-including-pictures.html
http://www.satellites.co.uk/satelli...-faqs/81198-how-stream-dreambox-internet.html
If you want to do it via justin.tv. You'll need to figure out how to get Flash Media Encoder to capture the stream from the dreambox.
PS: The stream from the dreambox is in MPEG2. M3U is not a video format, its just file that tells the media player where to get the video stream from.
hungary2006
DREAMBOX 7025+
Suomi
SilenZ said:
Hello,
Try usb tv card on your pc and get an account at justive tv and it will detect ur tv card. I had try this at mogulous site and stream to their site. I did this many years ago.
spacemind
metronic
PT
SilenZ said:
You can use the app fiscstream to capture de video from dreamboxes and then stream from your computer to justin tv
spacemind said:
As this thread was started in May 2009 I would imagine he has either given up by now or found a way around it :D
hungary2006
DREAMBOX 7025+
Suomi
Few years back I have figured out on how to stream it. Jusst EasyCap USB to capture from Dreambox to PC.
