Dreambox dm800hd pro initialise hard drive
tosher
Dreambox dm800pro & Windows 7
Merseyside,UK
Hi
Can anyone assist how I get my hard drive to work on this box. Have installed it as the manual stated, formatted it as well but when I try to record. The box states not enough space. HELP!
As a first time user of dreambox no:confused abuse please
Tosher. Merseyside
MARK
Tenerife
www.satellites.co.uk
Sky HD+,Dreambox500HD,800SEHD,tm5402hdCI+SUPER+lots of other STB's,1mtr ISS motorised
Pc's far too many lol
Good ole Blighty
Have you initiate the drive??
Then rebooted the stb...
Format should be in fat32
tosher
Merseyside,UK
Hi Mark
Thanks for replying so quickly.
I don;t know how to initiate the drive except I used BP Menu >Device manager> (blue) menu and initialized it in the manner it described. then rebooted the box but don't know if it was formatted in fat32. when trying to record get message <100mb
MARK
Tenerife
Good ole Blighty
done abit of a search for you m8,have a look at the link posted.....
_http://www.satellites.co.uk/forums/dreambox800/178014-how-install-2-5-sata-hard-disk-d800hd.html
tosher
Dreambox dm800pro &amp; Windows 7
Merseyside,UK
Hi Mark
Thanks will try the link and lat you know
Tosher
goose68
dm800hd, 1.0m motorised dish. AMD Phenom 11x4 965, radeon4890, 2 x 1TB, 1 x750GB.
Northish Scotland
Don't format the disc fat32, it should be formatted ext3 for enigma 2. I would advise you to format the drive first using you'r pc, then install it in you'r box, and if you are using a recent image, the box will automount the drive, saving you a load of trouble.
tosher
Merseyside,UK
Hi
How do you formatt it via a PC and then to ext3 for enigma 2 - not fat32. Would you be more specific as I'm not very up with the IT jargon
Thanks Tosher
MARK
Tenerife
Good ole Blighty
Plug it into a spare sata connection on ur pc or gat your self a hard drive caddy....
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD Qaud 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
Most HDD's in Enigma 2 receivers are initialized formated like this: -
Menu > Setup > System > Harddisk > Initialize.
goose68
Northish Scotland
tosher said:
Hi
Thanks Tosher
Install the hard disk in your pc, then use paragon partition manager to format the disk ext3, then put it in your dreambox and you should have no problem. Or download a Ubuntu Linux and burn it to disk, then boot your pc from the Ubuntu disk, and use that to format to ext3.
tosher
Merseyside,UK
Hi all who have replied(thanks)
Have partitioned the disk, formatted the disk to NTFS (named it ext3) not Fat32 all to no avail. Used the Menu > Setup > System > Harddisk > Initialize. Still no luck.
Were am I going wrong
Tosher
redout
1M Dish with Motek 2100,
DM 500 &amp; DM 800HD, Vu+ Duo,
Digital+, Sky+, TDT, Saorview
Dublin
Tosher
Have you tried just hitting record button on remote?
I know it sounds a tad simplistic but I have actually installed a hdd inside a dreambox in the past and just started recording without ever initialising it and it has worked.
Just try it and see what happens.
tosher
Merseyside,UK
Have tried the record button on the remote and all that comes up is (Free Disk-size to small!!! <100mb)
tosher
Merseyside,UK
Hi to all who contibuted and thanks
Through trial and error and help I have got the hard drive working and recording tv programmes :).
This is how I managed to get the HDD disk to work.
1. Get a copy of SpotMau and copy their disk recovery CD.
2. Use your PC take out your old hard drive and replace it with the one you want to formatt.
3. Run your PC with the SpotMau recovery disk ( need to set your PC to boot up by the CD).
4. When the PC boots up run >A: fdisk and state (Y) large disk. then use the programme to partition the disk , then initialize the disk. After this is done close programme.
5. Restart PC and run SpotMau disk recovery and use the formatt disk option in FAT32 (number7).
6. Replace the new formatted disk back in your Dreambox and BINGO it should work.
goose68
Northish Scotland
Mate you could have problem's recording anything over 4Gb in size, because you have formatted Fat32, that's why i told you to format the disk Ext3 which is the correct format for Linux/Enigma2.
tosher
Merseyside,UK
Thanks goose68 for this
But I'm a little unclear in which format you are relating to - is it NFTS or something else. I did name the disk ext3 though when I formatted it in FAT32.
Regards Tosher
goose68
Northish Scotland
Regards Tosher
No you have to format the disk to Ext3 not just name it that. Ntfs/fat32 are Windows. Ext3 is Linux/enigma2. You will need to use a program like paragon partition manager to format the disk to ext3, as some of the program's can only format in Windows extensions types.
Look at the picture you will see what i mean.
tosher
Merseyside,UK
Hi goose68
Will do. Thanks for your help.
Tosher
tosher
Merseyside,UK
Hi Goose68
Have reinstalled the 2.5 hard drive formatted to ext3fs ( used Paragon Partition start up disk through PC). The FAT32 format did not record over 4.0gb, hence the re-format. Used the record button on remote and all is well with start/stop process. Hope this helps others who view this thread.
Tosher
