Dvr Nvr for CCTV
Archive-8
As most of you know I have a CCTV system installed in my properties. This is a mix of 4 analog and 5 ip cams.
I have been looking at changing the dvr for one with ip cams aswell.
A few I have looked at have 4/8/16 analog inputs and a max input of 2 IP cams. This is no good for me.
So can any recommend a suitable Nvr/dvr.
2cvbloke
Near Pontop Pike, Co. Durham
A reasonably recent PC with an analogue camera card installed, IP cameras only have to be on the network to be accessed by the software to record them... :)
The software I've been using is GeniusVision NVR "Community" (uploading streams to their community is optional), but there are paid versions too which offer more powerful recording settings:
http://www.geniusvision.net/
And that can be remotely accessed, either locally or via the web, to view the cameras and recordings... :)
Archive-8
I have been testing a bit of software called i-spy
All of the cams above are IP cams
That's the sort of thing I am after.
I have 4 Bnc analog cams and 5 IP cams at the mo. But I want to add a couple more IP cams.
Just I need a Nvr/Dvr to view it on.
The specification suggests it is a(n) NVR.
