Advice Needed Enigma2 With Motorised Twin LNB and Fixed 28.2 dish.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
It seems with any of the E2 images/boxes you can't have a second feed from the same motor with a Diseqc switch.
I've ended up just installing one of my CM 1.2's for the 2nd tuner, tuner 1 has the Gibby + 28.2e, all works fine.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
NL
So, just for my curiosity then (again):
Can you set a fixed or preferred tuner for recordings?
If so, that would maybe have made another solution possible, while not using "Second cable of motorised dish"; because it's clear now that that option doesn't work properly on your image when combined with a fixed dish.
Greetz,
A33
