Fixing installation
The Gibertini website doesn't appear to show any dishes like that - especially the thin feedarm, because the feedarms on all those on the website are more substantially/heavily built. @Channel Hopper may know more/better?
Doesn't look like a Gibertini to me, Maxx Digital Lite 120 ?
Look at the paintwork and the corrosion on the elevation adjustment
antrabe
dreambox7080 dm900 viark droi
spain
i cant find the manufacturer it seems aluminium. Which is the weight of this kind of dish.
antrabe
spain
The person who sell it say between 15-30kg then not ok for me.
By other hand i have tested maclean lnb mctv 670 and works very well anyone knows if exist the same lnb for prime focus? I dont know the brand.
The dish won't be over 15kgs with aluminium reflector
antrabe
spain
sonnetpete
wordpress.com
Normandy, France
Kathrein have a unique way of attaching their LNB. It's also nothing like a standard 40mm LNB shape. Perhaps you should be looking at a differing manufacturer who produces an aluminum or fibre reflector. The larger Gibertinis are aluminum and Laminas are fibre glass. However, the mounting brackets in both cases are steel. The Laminas 1200 (which I have) is 8kg with the AzEl mount.
antrabe
spain
Thanks for your info, i check gibertini but its heavier and maybe so big than this kathrein.
i found this adaptor
The dish comes with a lnb but checking the specifications are 0.8db noise i never tested this kind of lnbs but 0.8db seems too much. Maybe it works fine because seems good dishes this kathrein.
Let see because i can get the dish only for 30€ so is a good price and its in a good conditions as is second hand.
Yes laminas is only 8kg but i dont know if i can get it on those prices even here in Spain maybe is difficult to be found.
antrabe
spain
Next week i will receive the kathrein ws90 i bought also the adapter to 40mm lnbs if the kathrein lnb its not working as good as my mclean.
Let see if motorished this kind of dish works i try to find somehting about on the net but nothing found, somebody saw one motorished?
antrabe
spain
ITs this motor like stab? i cant find specifications on google.
Im thinking to install wih the kathrein dish.
Yes, that is a badged Stab rotor
antrabe
spain
i think measure 5.5cm the shaft, and i think its original stab HH120 im going to buy from a reseller thats why i have not too much info although the seller say that its for 1.2m dish lets see i bought only for 40€ then and its new without use. Even if its 100HH could fit to my new dish which weight its 13.4kg.
The manufacuturer i found out that is daxis.
antrabe
spain
received the kathrein antenna its seem very good quality dish its comes with this lnb but seems that not works as has H/V separate. Anybody knows if could works like a normal lnb without splitter or switches?
antrabe
spain
The lnb has very good picture quality on both SD and HD, could be able to works without a switch?
The dish is heavy also 13.4kg tomorrow i will check if the rotor stab hh 120 can move it witouht any issue according spec 18kg.
antrabe
spain
With a diseqc 4x1 could works .................
antrabe
spain
Received the rotor its seems a original Stab HH120 mast length 18cm and diameter 5.5cm lets see if can handle the kathrein dish.
Also I receive the lnb holder god quality also. i will test both options standard lnb and uas584 with diseqc let see..........
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Received the rotor its seems a original Stab HH120.................................
some
Yes, certainly looks original........I have attached a pic of my Stab HH120 installed some 14 years ago and still thankfully working great.
Good luck to you :Y:Y
