Guide to watch AVI DivX Xvid on your Dreambox using VLCF (Video Lan Client Frontend)
peroni
90C Motorised Dish, Dreambox 7000s, Gemini, S*y Italy CS
Northumberland UK
See attached PDF, I hope its useful.
;) Peroni
  • VLCF.pdf
kamnitesh
Optus D1 & D2, connected with Deambox s500
New Zealand
Thank you....
ye7ia
DM500
france
This procedure works only with gemini image.
Is there a procedure who works with nabilosat image ?
ajay1010
reciever s emubox u
astra
netherland
It didn't worked for me , it is ssaying the vlc is not connected
solitus
d600t d700
sweden
doesnt work for me either.. can figure out whats wrong.. no FW enabled on pc etc..
rrobyxx
wavefrontier t90 dm600
Norway
im on a 64bit xp, this dosent work, maybe of that????
pilpja
dm600
malti
Hi Guys, I tried this and it works. Only thing which is wrong in the tutorial is that the VLC shortcut should be exactly as follows (including the "):
"C:\Program Files\VideoLAN\VLC\vlc.exe" --intf wxwin --extraintf=http
enjoy!
steve
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
Rather than rely on a command that could change from system to system, you could just start VLC normally and go to 'View -> Add Interface -> Web Interface". This does exactly the same thing. You only need the command line if you want to auto start VLC with the web interface enabled.
johnygoon123
dreambox800 hp laptop rooter lannetwork
miltonkeynes
nabilo dosenot have vlcf plugin and it has in my dm800 green botton vlc server to be edited by hand and has webinterface conf too.
and how to command to vlc and where to change the ip
Th Ref
DM 600 enigma 2
malta
I have a dm 600 and I have downloaded vlc and works fine but I want to steam from pc to dm and I have seen the instructions, but you did not make it clear how to install step by step vlcf in dreambox
toysoft
Dreambox 7020-S
Switzerland
AVI files play fine directly on DM8000 and DM500HD, without extra software or streaming... best boxes as this is a good improvement compared with the older DM800.
TS
Robbedoes
Dreambox 7020
Netherlands
DM500HD, DM8000 and DM800 will play AVI, MKV, m2ts, VOBś and more.
I'm using OpenPLI-2.0 image, with his downloadserver verry good!!
albarrag
consern about computer and internet
saudi arabia
thank u so mutch
