Help and Advice sought!
nicolas46
Nottinghamshire
Southwell - Notts
Hey there,
I am trying to find out if anyone could help and advise me. Basically I have a Technomate 7100HD Triple Tuner with 90cm Motorised Sat. Dish!
I want be able to watch the blocked channels I can receive from all of Scandinavia!!?? Is this possible? How much does it cost? And how easy is it to sort out??
As you can probably tell I'm not that technically minded, so any advice will be VERY VERY appreciated!!!!!
Many thanks
Nicolas:confused
Several of our forum advertisers do Scandinavian subscriptions, not sure what they cost though.
Scandanavian subs aint cheap if you have to use a UK based reseller!
Much cheaper if you have contacts who can arrange it in the country you are interested in
I used to have a subscription with my Finnish contact for Canal+ Nordic, which was 29 Euros a month for all Canal+ and local Finnish channels. It did not include the usual "entertainment" channels. Quite pricey but good channels.
