Info on every CAM in existence
stewie_uk
ictcphs said:
Does anyone have any upgrade info for an OnDigital Media Guard CAM?
If you mean the old UK terrestrial service, I'm pretty sure they're Seca 1 CAM's, not Media Guard, but not much good for anything as they used a varient that's not compliant with satellite broadcasts (anyone please correct me if you know different).
ictcphs
Visit site
These CAMS have MEDIA GUARD blurrbed all over them in very large type.
Nigel.
radiotech
Visit site
USA
I live in the USA. Based on the information on lefdata. Is this the good I/best irdeto CAM to purchase? Numbers on the back are 900440 and C1016307742, Manufactured by SCM Microsystems, DVB Number 00 1608. Thanks in advance.
Yep, the 900440 is PC flashable to Freecam 2.018 or 2.019
Thanks silvernet, yes, they went down a few days ago, hoping that thye will be back up in time. :)
radiotech
Visit site
USA
I have a viaccess red cam, part number 901273 Rev 1.1. Can i convert this cam to freecam? According to the lefdata site, i have to open the cam and replace the flash memory chip. I can do that without any problem. However, i don't know which flash i can use to re-flash the cam. Any helps would be appreciated. Thanks in advanced.
Don't know TSD, it has been down for a while, hope they'll be back soon, it was an excellent reference site.
Cheers, good news. :)
elnispero
Near alicante(spain) or abingdon(UK)
2old4this said:
Some great sites for info on just about every CAM in existance
http://www.lefdata.com/ci_ca/ca.html (CA CAMs)
http://www.lefdata.com/ci_ca/ci.html (CI CAMs)
http://www.prgh.tk (CA & CI CAMs)
backdoor for the last site is:
http://prgh.freehosting.net/
2old
Hi Im eddie and you sum up my status too !!
would like to contact member re cams and modules for receivng progs on hotbird and hispasat but everything seems to be changing out there,,I live in spain and have 2 manhattan 3000 recvrs but my matrix relaoded cam does not seem to work !!
help please !!
Eddie down on the fruit farm yes really oranges and lemons
caretaker
Where can i download a "proggy xcloader"from? Thanks in advance.
JAX
Super cool links man.
Answered to all my questions until now.
zerizes
HI
I bought a Magic Cam few weeks back, and I don't know what I can do with it ; it seems that the Dragon is the best. So please give me some help.
Regards
Zeri
Tiggy
Sorry but I have no experience with this Cam.
There are plenty of links and groups associated with this Cam, I'm sure that with a little further research you will find what you are looking for.
Sorry that I couldn't help you any further,
Tiggy :-bunny
