Is there a wifi solution for the 7025
chrisfound
Dream 7000 + 7025
Sky+ box, On-Dig,
3 laptops, 1 desktop, Win XP and soon '7', OSX on one laptop
London UK
I am in a not unique situation where my broadband modem is two rooms away and everything connects via wifi, however since the dreambox was launched there has never (that I know of) been a way of connecting an external wifi to it (wep encrypted).
So are we still in the dark ages in relation to this, or has someone finally resolved this problem
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
I have one of my box's connected with a belkin gaming adaptor which is fine.
A better solution though which a friend of mine has is home plugs.
He has 200mbs plugs and they are as good as having it wired.
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
Wifi works perfect on the 800 but I dont know about the 7025. If it works the same way you dont get the option of wifi until you put your usb dongle in the dreambox. Once its in the wifi connection is available in the network settings
Replay 2
Dream Box 8000
500 GB Samsung HDD
Sony DVD
Dubai, U.A.E.
I have an USB adaptor by Linksys with Gimini project 4.5. works like a charm in DM7025. :)
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
As long as the required location is on the same mains supply I recommend the Comtrend powerline adaptors and stick with a cabled solution
Gentleman_1
Dream Box 7025+, Skystar2
UAE, Dubai
I have a Gemini 2. Does that USB adapter work on it? How do I look for it?
Replay 2
Dream Box 8000
500 GB Samsung HDD
Sony DVD
Dubai, U.A.E.
If you have a Linksys wireless router, get the compatible usb adaptor for it from any computer shop.
aamir007
PC: Intel Quad Core 2.55 ghz 4gb ram Nvdia Gforce 7900
PS3
Dream Box 500\518\800
West Yorkshire, UK
_http://cgi.ebay.co.uk/OpenMedia-Wifi-Bridge-Make-Your-Dreambox-Wireless-/200494895863?cmd=ViewItem&pt=UK_ConEle_SatCableFreeview_RL&hash=item2eae6d52f7#ht_1746wt_704
That'll work on all dreamboxes including the 7025 as it requires no drivers. All you have to do is connect it to your laptop and run the set up and connect it to your router and then connect it up with the box and it should work perfectly fine. Plus it'll be cheaper than a home adapter plug
Zarc
Dreambox 7.25
Cyprus
Many thanks for that link, it works a treat.
