Jaeger 1224 restoration/modification
Hi Rimant,
Any updates? I saw an interesting thread here (in Russian) where someone also reenforced their 1224 motor. Quite simple - even something I could do!
Some pictures from there:
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Hi Alex! No updates at my side.... I've seen this project. It is Skystar from Hungary.
Yes, I am still wondering how it will drive a 1.8m CM in its reenforced form. Scared but much more preferable to a PM.
anto@
italy
Sorry for my bad english focus on my rigid system Gibertini 150 a strong wind broke the motor mount that I made some changes to make the most robust all I am now more confident with regard to strong wind
outer plate 1 cm thick
thickness of the inner sheet 5 mm
piatti sulla scheda principale di montaggio secondo motore
Great work! Shame that these motors are made of such weak alloy.
RimaNTSS
N-E from Riga
Last night I've realized that I have too many started but never finished projects :oops:, and Jaeger 1224 is one of them. There are several reasons for this situation, like "another priorities", " technical difficulties to solve some issue", "lost of interest" and others. So, to keep Jaeger 1224 project alive, made Panzer plate (@Trust1 drawing). Of course, it is out of 5mm INOX, heavy and strong. Not sure will I install this plate in my motor though, as there is already enough strengths in the construction.
I would put the plate in it. Those motors are renowned for the housing breaking in two. They are nowhere near as tough as they look. I've got the plate in mine.
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
Hi , i'm also looking to buy full set of SS bolts for this motor . Any ideas ?
Or a good way to restore what's left of the old ones .. Vinegar maybe ?
I usually buy a set on eBay - as long as they are the same size, they will work.
Just be somewhat careful about the strength of the bolts you get - that can vary quite a bit, so you need to look at the embossed ratings on the heads of the existing ones and buy some that are at least as strong.
Some of the sizes of the original nuts/bolts shipped with the Jaeger 1224 were unusual, they were not standard metric sizes with a common pitch. They used a variety of thread types, metric and UNF come to mind. However, you should have no problem replacing them with stainless steel versions in metric that are very close to the original sizes.
If I recall correctly, the V bolts (20 tpi), the elevation saddle clamp bolt and the elevation pivot axis bolt were unusual thread sizes and pitch with the rest of them being standard metric sizes.
mariust5
hastings , uk
Ok , does somebody have or can make a list with what's needed to replace all if not most of the bolts required ?
I'm not very clued up on Bolt measurement .
Tsiklon
Various
Europe
I'm trying to remove the triangular metal plate which attaches to the top of the motor axis on a SMR1224.
I've removed a small screw-head bolt from 1, removed another small bolt with an allen key from 2, and removed a nut from 3. But the triangular plate is still firmly attached, with no obvious way of removing it. I'm not sure how much I can force it, or am I missing something.
In particular, what purpose does the nut on 3 serve - my guess is the threaded part must also be removed somehow?
Any help greatly appreciated!
Trust
Nijmegen Netherlands
At that piece of M6 rod you can screw a M6 long nut to pull out that spigot which is secured with a M5 screw at the opposit end .
Hammer it out from the other side after putting some tension with that spigot puller .
That spigot and subsequent removal of the triangular section is an utter pain. I removed several and all have been as bad as each other. Plenty of penetrating fluid and patience...
