Vipersan
Emmett Browns Ghost
- Jun 29, 2009
- Age
- 67
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
As you may know ..I've spent the weekend assembling and fitting a Ku circular lnb (modded SL3) to Christina ..
It did me no good but having fitted it ..I wanted to keep it in the system ...
Who knows ..one day it may prove useful.
Problem ..
I had no more switch spaces left so ..
Time for a re-think..
By using a combination of a 4 way diseqc 1.0 ..to basically controll V boxe/motors and one of my Usals dish/motors (Tom)..and leaving one position (4) ....I could switch away to this position thus disabling motors routed control through the 4 way switch ..allowing any motors controlled via the 8 way diseqc 1.1 switch to function correctly..
By doing this I have freed up position (3) on the diseqc 1.1 switch ..highlighted in the green box ...to connect up one more lnb.
..the Ku circular SL3.
various combinations can now be used of 1.0 and 1.1 either singularly or in combination to shift the wanted motor and dish ..and the required lnb ..
Not fully tested yet ..and I WILL have to make a crib sheet so I know who what which and where ..
But In my head I can't see why this wouldn't function.
Time will tell...
This diagram is somewhat simplified as there is also the band switch (SL3) ..and the 3 smart priority switches in the mix as well..
but these have been left out to simplify ...but tested ok and functional.
rgds
VS ..with a mighty confused brain..
Problem ..
Time will tell...
rgds
