Listen Up MIS Multistream Channels: Easy Reference
MCelliotG
Thessaloniki, Greece
Hi Adam792, do you use E2 box?
TSID is not the input Stream!
Same SID on different Input Stream with same TID and NID, enigma2 don't like that! (file "lamedb")
IS33 DMAX SID=50
IS34 Alpha SID=50
IS34 ibox65 SID=60
IS35 RadioItaliaTV SID=60
IS35 Spike SID=50
IS35 SUPERTENNIS SID = 40
IS36 Deejay TV SID=40
This is a problem for the 5W transmission only, the 12.5W transmission has different SIDs as it should.
However, this issue is solvable in E2 when the Ignore Subnetwork for DVB-S value is off! Very useful for 5W in many ways....
New symbol rate, fec & Polarisation on NURTS Bulgaria @ 39 east
NURTS Bulgaria Multistream 3 Hellas Sat 3 @ 39 east
New symbol rate 10410, Polarisation is now Vertical FEC is now 2/3,
12593 V 10410 2/3 DVB-S2/8PSK MPEG-4 PLS: Root/218997
bTV 5152 5153 Bul
Nova TV 5162 5163 Bul
BNT 1 5172 5173 Bul
BNT 2 5182 5183 Bul
BNT HD (SD) 5342 5343 Bul
Bulgaria On Air 5332 5333 Bul
Thanks to satesco for the fec that my 2 multi-stream receivers do not display.
All noted.
Sadly no signal still ...... need to wait for leaf-fall.
MCelliotG
Something really weird is going on with NURTS. On HD51 I have absolutely no signal. On my TBS the signal is booming with 18.3db!!!
Another driver issue with Silabs?
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
It' ok now with my SF 4008
12593 V 10410 3/4 DVB-S2/8PSK MPEG-4 PLS: Root/218997
Transponders active on the higher bandwidth at 5.0W.Got them with 110cm dish.12515 H,1666,3/4(channel RASD-come back) is from 4.0W
EnoSat
enosat.euweb.cz
Slovakia
test HD51 with both PLS ?
stephan94
Bavaria
From Bavaria perfect reception with all my devices (TBS 6983; SF4008; SX88; SX8HD One) 39°0E_12592_V_203327.jpgEncode_1080P_36.mp4_20180805_212125.340.jpgEncode_1080P_37.mp4_20180805_212207.196.jpgEncode_1080P_38.mp4_20180805_212250.067.jpg
The latest software for the SX88 & Primo S2 found the new transponder data on 39 east,
I deleted the multi-stream transponders when the parameters changed & both receivers found the new transponder data :):Y
MCelliotG
I stand corrected, I was inputing the wrong SR. The signal is fine at 17.9db!!!
And SX88/Primo would naturally find the new data, the PLS is the same!
lovinthetelly
Sky+HD, Wavefrontier T90 with 16 quad/octo LNBs receiving 42E/39E/33E/28E/26E/23E/19E/16E/13E/10E/9E/7E/5E/3E/1.9E/1W/5W/12.5W through 3 EMPCentuari 16-way DiSEqCs to TBS6522, Octagon SF8008 & Edision Primo IP S2.
90cm for 7W/15W; 1.2m CM in storage.
Mediaset Italia have shifted their HD services around again.
Rete4 HD and Mediaset 20 HD have moved from 12522V to 12627H 25000 8PSK 2/3 MIS1, root 8.
Mediaset's 4 FTA HD services are now together on the same mux, and all carrying English soundtracks. Previously only the SD services had a second audio stream.
This follows the closure of Investigation Discovery, Eurosport 1 and Eurosport 2 on the Mediaset Premium DTT platform.
lovinthetelly
one small correction- the correct SR is 35000.
Just been updating 5W as above, and further housekeeping : 12606 V 35000 seems to be inactive.
Can someone confirm?
Adam792
Cheltenham
It’s on as far as I can see! Just tuned in to La 7 HD a couple of minutes ago. 35000 2/3 PLS Root 8 Stream 1 and Stream 2.
Hmm. All parameters are entered ok, and LA7 etc. previously worked.
Glitch or finger trouble, then. Thanks!
LateAdopter
80cm fixed, 4 position switch
28.2 E, 19.2 E, 13 E, 5 W
Xoro HRS8500, Edision Primo
12522 and 12606 went dark on my Primo when the other HD channels moved off. There must have been some change that the Primo can't handle.
I tried rescanning 12606 but no result.
Yep. Dead as some dodos.
I recall having a similar issue some months ago and got around it by deleting all 5W TPs and rescanning.
Not that fussed for now as we don't watch the LA7 Channels anyway.
LateAdopter
The 12606 SR is now 35500 then it's OK
Interesting. Just going to edit ......
