Just Sharing This Moved house - Scottish Borders dish farm v2 & v3
Topper
Topper
Amo Amas Amant Admin
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
Perhaps CJ meant HRT:rolleyes:
Skybox F3
At 51.5E the Belintersat European beam has come back on air (11350H 45000) with a massive signal, so thats another slot added into the log here :)
Skybox F3
A friend turned up today with 2 60cm Sky dishes in the back of the car :D. One is to be handed over to the chap 2 doors down as he was given an old Sky box but has no dish. He wants a few extra free channels so I promised him Id set something up as soon as a suitable bit of kit turned up - whilst I had a couple of dishes lying around I cant find the mounts for the damn things - they got mislaid in the move.
So now I can make good on my promise :)
OP Gibertini 100 XP+ Inverto Black Ultra 0.2
(50 east to 34.5 west)
TM6902HD (A/B switch) Octagon SX88+Optima
Raven 88cm Mesh Dish + TM-1 0.1
Octagon SX88+ (A/B switch) Edision S2
45cm dish V8 Golden 28E FreeSat Quad Lnb
Virgin Media FreeSat
Skybox F3
I put the Fraccaro Penta back up today - aimed at Hotbird as Ive been having issues with the original 13E lnb in recent weeks. Having sorted that one out now I need to get 9E & 5E back. as those lnbs have moved or failed. Might have a try for some of the slots Im missing as well. if the weather holds up
Good luck with the changes - Xmas Day weather looks "relatively promising" for us "down South", and hope it will be the same you lot "up North" :)
Skybox F3
Its amazing what you can cobble up using 3 scaffold clamps that came out of a pile of scrap metal and some lengths of old scaffold pole which came out of a skip! :D
Norman Foster could learn a lot from you.
Skybox F3
5E & 9E sorted & as a bonus 3 or 4 of the stronger tps from 10E have appeared as well. :)
Skybox F3
On a very cold afternoon, & using hand held lnbs Ive managed to get very brief tp locks on 2 new birds this afternoon
26E - 11996V 27500
27.5W - 11495V 44100
No channels scanned so I wont add them onto the list in my sig just yet.
26E - 11996V 27500
I think both sats - especially 26E - are difficult to get if you're not using at least an 80cm dish centred thereon.
Skybox F3
26E was offset on the 1.1m aimed at 16E. The nearest equivalent frequency on 28E seems to be off atm.
I will check further and see if I can get some channels scanned when its a bit warmer outside.
27.5W was offset from the Hispasat dish. I might realign this one onto 22W though at some point.
Skybox F3
A bit of a surprise checking the 5E channels this evening & updating the tp list - Ive got one solitary Nordic beam frequency appearing! Not bad on an offset lnb on an 85cm dish aimed at 13E :D
11996H 27500 3/4. Its only DVB - the Astra 4A DVB-S2 frequencies are below lock & its as it is 11996H is extremely marginal.
For the record heres Swedish Kanal 10
Skybox F3
A lovely day up here this afternoon, absolutely no wind & pleasantly warm to be outside. So Ive been working on the 22W / 30W dish which had come loose over the wonter & moved a bit..
2 new satellite slots logged after a bit of tinkering 14W & 15W :)
