My own construction, 23dB gain, motorized aerial
iggy
PrimeFocus 180cm (Astra 1N) - Inverto Volksbox IDL6651n; MABO 115x128 (80E - 30W) - Dr.HD F16;
EchoStar 80cm (Hotbird + Astra) - Kathrein ufs910.
KRAKOW / POLAND
Hi guys, I wasn't sure if this is right place, but it seems appropriate :)
My own construction, 23dB gain, motorized aerial. Camera installed underneath to control position.
It is capable of receiving signals from 130 km distant tv transmitters, e.g. Czech transmitter located on Lysa Hora mountain.
Pretty impressive iggy, the windage on that unit must be massive, do you get any movement?.
Oh very nice - I used to enjoy terrestrial tv dxing back in the days when the ITV regions carried different programming. My setup want as fancy as that though - it was a battered second hand aerial hung out the bedroom window on washing line!
:-lmao
I managed to get Dutch TV on it once during a lift from north of Birmingham
Hixxy1
East Midlands
I've heard of people picking up Dutch DTT in Lincoln. It's a bit of a mission as they only use 10kw but are also vertically polarised which helps quite a lot.
Good setup there Iggy. Are you using any amp stages like a masthead amplifier or launch amp?
iggy
KRAKOW / POLAND
Well, I am always feeling bit concerned when massive winds blow, but luckily my system survives them all. What I do is aligning aerial with wind direction, so that the impact isn’t that destructive.
My record is Berlin Alexanderplatz, more than 529 km :) Pictures below
I am using LNA-177 30dB amplifier, mounted directly on dipole
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Great stuff iggy! When I get satisfaction from SAT TV, will probably pay more attention to terrestrial. I like camera you have installed under antenna. What kind of camera is that? And how do you turn your antenna?
iggy
KRAKOW / POLAND
Regular VGA camera with IR reflector. System is rotated with manual controller. You can google out some details on it - AR-303
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Happy New Year!
Some analog & digital(DVB-T2) channels(last 3 photos) receivable in Varna from Ukraine(Simferopol) abb.530 km.
Antenna - remote controlled rotating antenna 20-28 dB gain - modificated(two 5-elements arms up&down added)
mouse3
1.2 offset,1.2 simetric ,0.9 offset.
Transilvania
This it s my homemade UHF aerials for Bulgarian digital DX-ing.It was one summer project,3 months of hard working.
mouse3
Transilvania
Reception from Shumen and Russe,channel 26 and 28.
hairybadger
Bricoleur
46.1N 6.4E
see sig
Hi - I understand how you calculate the length of the driven element, but how about the directors and reflectors? Idem for their shape. Is it a matter of educated guess and trial and error?
hexah
Hadrians Wall
That is brilliant. Well done!
:-celebrate
I just wish they would bring back Band I transmissions.
mikeisyou
Feed Hunter
England
Interesting stuff guys, is it possible to use a satellite dish as a terrestrial UHF antenna?
hexah
Hadrians Wall
It is easier to buy a parabolic uhf antenne like this 120cm AN6111K from Engel Axil.
The principle is the same as a satellite dish except the signal is reflected back to a small log periodic. The feed line goes up the pole and in the back along the feed arm to a connection point where there is a small masthead amplifier built in. It is similar to the barrel types used for the active antenna concept developed by the DVB organization and only really used on the continent.
The f/b ratio iirc has been given at around 30dBi.
This is an old and well proven design. You can stack a pair or make a quad but anything more is unrealistic for most people due to the wind pressure.
They must be installed with free space behind as reflections e.g. from being installed on a wall will interfere with the wanted signal when amplified.
Probably the biggest mistake people could make would be to have too much amplification at the masthead because it will amplify local electrical noise and cause annoying dropouts or hide the weakest signals. The masthead amplifier provided is poor anyway and replacing it with a known good unit from e.g. Vision or Proception would be a great improvement. Antiference still makes grouped mastheads and they can be used to avoid strong out of group signals from interfering within the masthead or receiver (the barn door effect).
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
ot:
the best antennas for DX is 4x Triax Unix 100 E21-50 ,stacking together with Triax comb.741 (loss 0,3d:cool: +amp.
I have been using this in Tallinn now about 5years.
The dipole is simply a receiving device which becomes efficient at the VHF and UHF frequencies when the prongs are of the correct length. A parabolic antenna is nothing more than a focusing device. Combining the two will give you something that can be used in much the same way as a yagi, though buying new will cost more than an off the shelf aerial.
If you can source a decent sized dish for pennies then you have the beginnings of a good directional receiving system. The downsides are the cost of changing polarity, susceptibility to winds and with that the potential cost of safe motorising, which is why the military have usually gone down the phased array yagi designs for most frequencies up to L and S band, or 2-4 GHz
http://www.ausairpower.net/APA-Rus-Low-Band-Radars.html
hexah
Hadrians Wall
The X elements on the Triax Unix can be a problem, they can crack, fall off or catch the wind or snow. They are not popular here anymore.
Here people prefer Antiference or Blake. The X elements are round which deflects the wind much better. Remember we have big wind storms like hurricane bawbag.
Blake uses solid round X elements and their antenna of the same size is heaver than the Antiference which uses hollow X elements (I own both).
Wisi used to make low windage high gain aerials with compact reflectors and round elements. And some good grid antenna with directors for quad stacking.
Kathrein made an excellent combiner. It might be the same as the Triax with a different label.
mouse3
Transilvania
I found that atx-91 it s expensive here,so, do it yourself.:)
So,no problem with calculations,but lots of working and precision it s not the last.
hexah
Hadrians Wall
mouse3
Transilvania
Intresting antenna,jbx21 but very expensive there,one hundred pounds.
Here with post and package atx 91 its little over 40 euros,made in Poland.Hurricane and strong wind are not available in Transilvania.
It s the last think i want, replace each year antenna after storm season.Better i replace wife,it s free.
