I have dreambox7000s system and upgraded the flash to 1.08. Since then I can not get things work properly.
I downloaded softcam keys from internet. I am more interested by the french channels.
With 1.07 I used to use the key wizard to copy key files to xcamd.
Now since I upgraded I can not access the key wizard anymore and the xcam deamon does not seem to be there any more.
I telnet to the box to check if the 'emu' deamon or xcam deamon are running but they do not exist any more.
I am trying to download them from internet but I am quite worried about the versions I am getting and I am not sure about how to set this up.
I would appreciate if some one could help me set the deamon that reads the softcam.key file to be able to get my channels back.
Thank you and best regards,
Aliban
Aliban
