Advice Needed New build satellite system
E
Edgeyboy
Sky Q
Cambridgeshire
First post...
I am helping a friend who is building his own which is near to completion, on the data (all sorted) and TV / satellite distribution system.
There are 3 bedrooms, a kitchen, living room and summer house (6 rooms total) to feed with TV/Freesat. The living room may have a SKY Q box in the future too so has been wired with an extra two CT100 cables. All six rooms have been wired with 2 no CT100/WF100.
I have been recommended the following products for the commissioning stage of the install:
Terrestial TV Aerial
60cm or 80cm Satellite Dish with Quattro LNB
2 way Vision dscr multiswitch + PS
12 way Vision multiswitch + PS
As I understand it, it will work as follows:
Outputs from the Quattro LNB feed into Vision DSCR cascade multiswitch. 2 outputs to SKY Q in living room. 4 outputs then feed to Vision 12 output multiswitch which supplies the 6 rooms (2 each: one satellite, one terrestrial tv).
Does this sound ok?
Thank you for any input.
Tom
I would stick a hybrid LNB outside, run all six cables into the point where all cables get sent out and use a distribution switch with fixed four port voltage/22kHz settings.
But the choice is yours.
E
Edgeyboy
Sky Q
Cambridgeshire
Thank you. Would you be able to expand on which switch might be good? Originally we were going to use a Delta 16 port switch (and send Sky Q straight to wall points bypassing this) but I was told that the solution I listed was more robust and better at long cable runs. Thanks agin
It's been a while since I installed one, but Spaun always had indivdual settings for their SMATV boxes, allowing a quad LNB to be installed without trouble.
Others off the top of my head would be Fracarro Switchline (ex Philips) and Triax (via Farnell)
I have a delta 8 way unit lying in the shed, and I think it also had dedicated 14/18/22k on each port, but would need to look at the specifications
I would use dish with Quattro, an 8 way multiswitch and four universal outputs from that feeding into a Triax TMDS 42c, that would give you 6 legacy feeds with Terrestrial and 2 dSCR/Legacy feeds with Terrestrial for the lounge.
If there are already dedicated Q cables run I couldn't justify the the money on legacy equipment when terrestrial is catered for in the main amplifier.
(but I would need to check pricing to be sure)
Since the Q system is only good for three points please let your friend know this should be treated strictly as secondary.
Have to say that if I were installing the system, my recommendation would be a Terrestrial feed to all rooms and a pair of wideband feeds plus a Terrestrial feed to the living room, unless of course the customer already had a Sky HD system that he wanted to maintain, or already owned Freesat PVRs, otherwise as Channel Hopper says above, the Legacy multiswitch and equally the dSCR is an unnecessary expense.
D
davemurgtroyd
Oxford
Oxford
Q I believe caters for up to 5 points but only 3 can be used at any one time.
Which means for the 2.4 kids and poodle family, its a three point system.
