Advice Needed New diseqc motor to replace technomate tm 2600 h-h
shamone
shamone
Vu + Duo, Mut@nt HD51, Icone Wegoo,
1.3M Dish, Technomate TM-2600 Super,
Inverto Black Ultra 0.2dB LNB, 53E - 30W + Fixed Zone 2 on 28E,19E,13E
N.E UK
Small update on my issue.
The dish started moving again on Monday night when I checked so I thought that all was good.
Had a flick about last night and the dish is now stuck swung around @ 52e after checking on the 'broadcasts' of the football.
So a TM2600 was purchased from WOS there and then.
Thanks for the recommendations CH and TJ
OP Gibertini 100 XP+ Inverto Black Ultra 0.2
(50 east to 34.5 west)
TM6902HD (A/B switch) Octagon SX88+Optima
Raven 88cm Mesh Dish + TM-1 0.1
Octagon SX88+ (A/B switch) Edision S2
45cm dish V8 Golden 28E FreeSat Quad Lnb
Virgin Media FreeSat
You may only need to reset your motor:-
Select DiSEqC 1.2 then delete limits & recalculate now select USALS DiSEqC 1.3 & your motor will respond if not try to delete limit & reset the system this can only work in DiSEqC 1.2 then revert back to USALS.
shamone
shamone
N.E UK
New motor arrived and switched out for the old one.
Small bit of tweaking before the rain hit and back up and running again.
Once the weather gets better:-rofl2 I will peak the signal.
A quick look at the old 2300 once it was off and it had swung around to 70e.
I had never sent it to that position, so it looks like it got lost before it gave up the ghost
I will have a look at the 2300 when I get some more spare time and see why it failed
Quick delivery and resolution.
It would be good to see the interior of the 2300, once I get confirmation from customer it's OK to dismantle the one I have here I'll do same
