NEW MOTOR AND LNB
rasp54
VU+ SOLO4K
80cm TRIAX DISH
TM 2600 M3
South Wales
My system consist of vu+ ultimo 4k one fbc tuner, triax 80cm dish.TM 2600 MK3 and TM gold twin lnb both new. Installed them both set the motor to 0 . Put the dish back up. the tuner config i got is B is set to advanced and A is set to second cable of motorised dish is that right as the dish is moving but no signal .ps am i am not using USALS
Manikm909
Small'ish Dish Man
Kent, UK
"put the dish back up" ? how do u know its aligned, its not magic
Mickha
North West
If you're not using USALS, I assume that you're using Diseqc 1.2, in which case you need to manually store the positions.
Go into the Menu, Setup, Tuners, and use the motorized function, to move your dish, to each satellite, then, once the signal is peaked, store the satellite., on a unique number, and move to the next, until you've stored all the satellites, on different numbers.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
You need to align the dish with a portable meter or non engima2 box such as a technomate. As you be hours otherwise relying Engima2 signal meter! As it doesn't update fast enough. Maybe download some channel lists and try U tv on 1w if you only got the vu.
rasp54
VU+ SOLO4K
80cm TRIAX DISH
TM 2600 M3
South Wales
Because i marked the pole.motor and dish before removing them.
Mickha
North West
All you need to do is as I have already posted above.
Go into the menu, Setup, Tuners and scanning, click on Tuner B, and set your satellites up, e.g. Astra 1 19.2E, LNB 1, Diseqc 1.2 and store at position 19, keep doing that for all your available satellites, stored at their satellite positions, then go into the motorized setup options, and move your dish, to the relevant satellite, like 19.2E, and when you've got the maximum signal quality, store it at position 19, then do the same with the rest.
It might take a few minutes, but once set up it will move the motor automatically, when you select a channel.
rasp54
VU+ SOLO4K
80cm TRIAX DISH
TM 2600 M3
South Wales
Getting there quietly got 19.2 e. with the rain and tragedy in the family had not had much time to do it will get there. Thank you for the replies
Mickha
North West
Please keep us updated, with your progress.
