No Signal---hElP
dee
I have a motorised dish and an Echostar 808 2ci. It was playing up yesterday so i tried to fiddle with the Cable at the back of the receiver while it was still switched on and consequently lost all signals. Could it be possible that the receiver is faulty or a problem with the dish. I can move the dish using the receiver + RC but can't find any signal!
Please HELPPPPPPP.......
The
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
Hmmmm ....I'm not saying it's the worst scenario but........that's one way to blow your LNB.
Hmmmmmmmmm ... longer Hm means I'm more thoughtful. :D
Strange situation, if you had shorted out the connection, the motor wouldn't work, so assuming that a healthy voltage is going up the cable, you might try resetting the DiseqC motor to 0.
It has been known for LNBs that are connected the other side of a DiseqC motor to blow, the older Invacom models were prone to it.
dee
Many Thanks guys. I changed the LNB as advised and the signal came straight back. All is now fine. Thanks.
What make was the LNB Dee?
