OCTAGON SX88 H.265 HEVC HD
LateAdopter
80cm fixed, 4 position switch
28.2 E, 19.2 E, 13 E, 5 W
Xoro HRS8500, Edision Primo
Not noticed slow channel change, or lockups, on my Edision Primo :ph34r:
To lock up the Edision Primo: Start a recording then press "media" on the remote control or select "audio" on the remote control and try to change the audio stream.
The second case is understandable because a useful feature is that the Primo sets the current output audio stream as the default in the recording so that MPV plays the english sound on the french recordings without needing to select it. But you need to have identified which is the english channel before you start the recording.
WARNING: Having locked up the GUI there is no safe way to recover. The recording doesn't terminate at the end of the timer, the pwrbtn is not mapped into ACPI so that won't do anything. What I do is watch the blinking lights on the SATA to USB3 adapter that blink intermittently during a recording. Immediately some blinking stops I pull the USB out.
A safer way would be to disconnect the LNB which would stop the Primo sending data to the disk.
I am still on the .48 version.
:-buttkick I'll give that a miss!
4wd
Getting the picture
5 W, 9-13-19-28 E
Hello, you write about -format-, not the way to go, this is a command to do 'things' with already existing \ old partitions.
You'd want to get rid of all partitons and recreate a fresh 'rejuvenated' 1 partition disk.
First of all: delete all existing partitions (results in unallocated space for the complete disk).
Next create 1 partition using all unallocated space.
Format is not involved at all.
@4wd
Many thanks.
I finally got around to doing what you suggested (was waiting for another, much shorter, USB->miniUSB cable to arrive in order to do a couple of things at once), i.e. deleting all existing partitions and creating a single unformatted partition, and that appears to have worked.
The SX88 reports the partition as "Normal" and recording then seems to work (not yet tried for more than a minute or so as a test ) which I was then able to delete - but only after rebooting the SX88, opening the Record File Browser and then deleting the Recording.
Bizarely, OTOH, after doing the Deletion, the Record File Browser then displayed a "Recording" message but there was no "REC" message on the SX88 display, and there was no actual recording shown when I exited and re-opened the Record File Browser. Odd behaviour, but at least I now kinda understand what could cause it.
4wd
Getting the picture
5 W, 9-13-19-28 E
Good. Glad the tips were useful.
http://www.octagon-germany.eu/
Firmware (Software) Update V10503 19-10-2019
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
- Portal pop keyboard
- VOD performance
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
Firmware (Software) Update V10506 01-11-2019
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
- Some minor issues improved
- Small bugs fixed
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10507 17-11-2019
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
- Özel yaziliminiz icin
- bizimle irtibata gecin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10509 10-12-2019
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Solved Automatic Update bug.
2. Small bugs fixed.
3. Support www.octagon-forum.eu
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10510 16-12-2019
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. T2-MI New Driver - New PLP Structure support add.
2. Example:
Express-AM6 @ 53 ° Ost: 12652 N SR15284 DVB-S2 / 8PSK MPEG4 T2MI oder 3635 L SR15284 3/4 T2MI)
3. EPG Performance Update & improved.
4. Channel Switch performance imporved.
5. Wb Interface (WEBiF) Update.
6. YouTube New Update.
7. Fixed one video decoder bug.
8. Fixed one t-vod can not play bug (WebTv).
9. Support www.octagon-forum.eu
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10511 29-12-2019
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Switched FREE TV & FREE Radio to new Player UI.
2. Removed FREE TV password.
3. Added SW Version in first install Menu.
4. Added ARD Mediathek.
5. Improved Xtream (New functions).
6. Changed New YouTube design.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10514 19-01-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. New Main Menu Icons and Background.
2. Added Bootlogo and Menu Logo settings.
3. Added X-TV main page back.
4. Increase Mediathek.
5. WiFi 2.4/5.8Ghz: Added RTL8192EU, RTL8811CU, RTL8192DU, RTL8812BU
6. Added X-TV vod series search.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
OCTAGON GERMANY SUPPORT
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
shame all the remote controls are very poor build these days .
Excellent update all on line TV now working :)
Firmware (Software) Update V10515 26-01-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. New Video Driver upgrade.
2. New Weather Service added.
3. Nasche TV issue fix. (HW Transc.)
4. Anti-Standby function added.
5. Added 600 Mbps & 1200 Mbps WiFi support.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10516 15-02-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Menu - System - OSD Settings - OK: 1234
1a.) Format .jpg , Size 1280x720 Pixel, Max. 600KB
2. Boot Logo and Menu Logo function added
3. ASAT Logo corrected
4. VOD Player improved
5. .m3u High Bitrate contents improved
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10517 01-03-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Stalker functions improved.
2. M3U Vod Play improved.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
