OCTAGON SX88 H.265 HEVC HD
Google Translate version of today's post from Octagon Germany:
Today at 3:13 PM
Add bookmark
# 840
OCTAGON E2TV function (TV transmission via network streaming)
SatLess Multiroom TV client system
Enjoy satellite TV anywhere.
Without additional wiring via your network, satellite television is also possible on receivers that do not have a satellite connection.
Do you own an Enigma2 receiver and would like to use the program list of your Enigma2 device in another room as well, but without an additional antenna connection and as inexpensively as possible?
With an OCTAGON SX BOX (SX88, SX888) you can easily do it. Your transmitters receive it via streaming from other Enigma2 receivers that are in the same home network.
In addition to TV reception via the network, the OCTAGON SX BOX (SX88, SX888) models offer numerous multimedia functions such as YouTube, media libraries of public television and others
http://www.octagon-germany.eu/
Firmware (Software) Update V10520 11-05-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. New F-TV Function added.
2. Some minor issues fixed.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10520.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10520.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10520'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
galway
motorised and mutli sat
IRELAND
I have just received the new Octagon SX88+ Optima,
Excellent results so far I do like the new remote,
Blind scan works very well scans 10 east in less time than it takes to boil an egg,
Just one problem when I go to save my settings in Backup & recovery onto a USB stick only the DVB channel list is visible data that I can back up on the SX88+ Optima ?
On my Octagon SX88+ I can save all of my data onto a USB stick:-
DVB Channel list,
System setting
Stalker favourite groups
IPTV in Memory
CAM settings
Web TV data ect ect.
I hope this feedback will allow these features to be included on the Octagon SX88+ Optima,
I have this same problem. When and where do I enter the PIN?
Backup & recovery , try 4761 then the menu will open.
moonraker 1
1 meter ali dish tecnomate motor technomate fta rx pc desk top
salisbury wilts
I had technomate 5200 which is easy to move dish from satellite to satellite but the octagon sx88+ sweeps from east to west with out stopping and the step tuning does not seem to is this a faulty rx or me
Did you not read my reply in your other thread ?
Firmware (Software) Update V10527 02-07-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1.) OSD bug fixed.
2.) Add. New Color Buttons.
3.) Add. User Agent and Online Icon Support.
a.) Installieren Sie die aktuelle Firmware v10521.
a.) Install the latest firmware v10521.
a.) En son yazılımı v10521'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
3 Minor problems with the SX88 4K :-
1/ DiSEqC 1.3 USALS when I turn off the power at the mains then switch it back on the motor does not move, so I have to tell the motor to go to position then it moves to any satellite that I choose :eek:
2/ The remote control is not designed ergonomically with the Satellite selection button in the bottom left corner of the RCU so I use the SX88 Optima remote with the satellite button within easy reach of my fingers.
3/ Can we have transponders in sequence in the database ? As it will make my channel list updates easier & a lot quicker to compile.
Apart from that I am very pleased with this box.
Firmware (Software) Update V10522 17-07-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1.) Nashe TV improved.
2.) Volume Control Steps improved.
a.) Installieren Sie die aktuelle Firmware v10522.
a.) Install the latest firmware v10522.
a.) En son yazılımı v10522'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ SE C/T2 & SE C/T2 WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10526 27-09-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Option Menu extended.
2. DVB CH. List INFO Button added.
3. Media added to Hotkey.
4. Minor issues fixed.
5. Delete ALL channels freeze & hangup problem fixed.
6. Update os to latest version.
7. Modified bigger font size for subtitle.
8. Modified SID numbers limit for bis.
9. Modified the subtitle position.
10. Some osd & skin bugs fix.
a.) Installieren Sie die aktuelle Firmware v10526.
a.) Install the latest firmware v10526.
a.) En son yazılımı v10526'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10529 01-11-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. TV Online added.
2. Update latest OS Version.
3. WiFi driver fix 7601 - WL048 + WL058.
a.) Installieren Sie die aktuelle Firmware v10529.
a.) Install the latest firmware v10529.
a.) En son yazılımı v10529'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10531 29-11-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Default sort by number for Stalker - Option Button.
2. Add. User Agent for Stalker - Stalker Option - System.
3. Modified ATR of for Slovakia.
4. YouTube Improved.
a.) Installieren Sie die aktuelle Firmware v10531.
a.) Install the latest firmware v10531.
a.) En son yazılımı v10531'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10532 06-12-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
SX89
SX889
Changes:
1. Fixed sort by number for Stalker.
a.) Installieren Sie die aktuelle Firmware v10532.
a.) Install the latest firmware v10532.
a.) En son yazılımı v10532'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
SX89:
SX889:
Online güncelleyin!
Does this mean the SX88 (HD versions) are ending production? :)
More than probable maybe they will have fixed all the problems with the DiSEqC switches & motor that is why the new model has been brought out as it is not possible to correct the SX88 UHD hardware.
few times reply, IS NOT Software issue ! is box issue, you need to send to octagon.
no, why ending ? sx88 main hd models auf SX series. as i heard will sell until 2023
It doesn't make sense to manufacture multiple boxes that are nearly identical in function. Better to streamline the range and offer wider variety between models. All that is needed from the current range is:
SF8008 Twin / Combo
SX88 4K
SX89 HD
Then a version of SX88 4K and SF8008 with CI+ would be useful to many people but instead we are offered the SF8008 Gold! An SF8008 with internal hard drive would be nice too :)
