Remote Controll Problem, think its SW or Virus, AzBox HD Premimum
rogerk
AZBox HD Premium
Remote control problem
I have a strange problem my remote control is unresponsive
But I’m not sure it’s the remote being faulty!
It Started playing up yesterday replaced batteries no difference
Ended up powering down receiver and switching on again and it worked fine for a day
Re boot did not fix it
Sometimes the box continues to change on its own cycling through menus
Remote is not controlling even covered the led on remote
I think it’s a software problem or possible a virus or hack
Buttons on box work fine
Have reinstalled firmware on box, running latest on internet download
Box is unuseable anybody got any idea?
any help appreciated
john_graydon
Dublin....Ireland
Hi Rogerk
Havent any problems with mine so far, but would get onto support or maybe a new one, Is it still under warranty ?.
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
You should upload a new fresh / latest / FW and put in on an USB
Then save channelsettings, reboot and format the box before You upgrade.
pelimies
Satelliitti antenni
Tucholma
I got same problem as you. Any solutions found?
gonka
Amazonas 61W
chile
I got the same problem too with my Azbox HD elite. I've checked the front pannel looking for anomalies (diodes, etc) and everything work fine, except for a small piece located left bottom of the front pannel (inside) called 12.000 SB. This control de frecuency of the R/C unity but I dont have replacement for this one. I think too this could be a BIOS problem (corrupt), but I can take control of my Azbox using the "Azbox HD Remote Control" program and my deco work well; I can take 100% control of my azbox. If anybody have a solution, please post it !!
