Secret menu on Humax Freesat box. For DiSEqC & USALS
bigtone
Dream 7000
2xEurovox red
Humax HD
To access the hidden menu for diseqc settings and usals
Press
Menu
Setup
Freesat tune then press
Red Button
Green Button
Yellow Button
Blue Button
Green Button
Yellow Button
Blue Button
Then the Antenna settings option should appear.
and then you can access the Antenna Settings part of the menu. to set up your diseqc.
I have used this some time ago and its great for Multi sat reception.
STEWPOT47
Humax HD
France
Hi May I ask you a question.
If I change the diseqc would I be able to add a channel such as Horse & Country tv to the FREESAT channels?
SOrry if this is an obvious one.
Stewpot47
Horse and Country will appear on the list within the Astra 2 lineup on a motorised setting, it will not appear in the Freesat listing, or within the Freesat EPG.
STEWPOT47
Humax HD
France
Hi Channel hopper Thanks for that.
I am not sure I fully understand!
When I got my Humax I did a scan on Freesat got the full Freesat listings EPG.
I then did a none Freesat scan and got a different listing and was unable to see Freesat items. So I went back to the Freesat EPG which I use now.
My problem is my wife is a horsey perosn and likes H&C tv & would like the french Equidia as well I am a big fan of HD and would prefer to have it all on one reciever.
Any hints welcome.
Stewpot47
G
guest
Any hints welcome.
Stewpot47
Just go to Menu>Setup>Manual Tune
This defaults to 28E, so you don't have to worry about the Secret Menu and DiSEqC/Motor settings.
Then just Scan all, or select the Horse & Country Transponder only.
11623 H 27500 2/3
Done.
Retrieve Channel by selecting non-Freesat Mode.
PS: Not familiar with the French Equida Channel: What Satellite is it on? Is it Free to Air?
Edit: As you've apparently already done a Manual scan, your non-Freesat mode Channel list may already have H&C listed ................. That said, when I scanned mine, the TP lists were (as per usual with DSAT Receivers) not complete/out of date/incorrect, so if it isn't there , you'll have to add it (Go to the TP line and scroll to User Defined).
G
guest
For more general info about the Hidden Menu etc., I found this Wiki useful
_http://foxsat.wikispaces.com/
Equida is 19E & 13E and scrambled
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Just got a Humax HDR to play with for a few hours, just to confirm that the secret code for the hidden menu does work on that too.
However one disapointment is that when motorised antenna is selected, the unit becomes single tuner only capable. There doesn't seem to be a way round it.
obeonek
fta, freesat
cork
Press
Menu
Setup
Red Button
Green Button
Yellow Button
Blue Button
Green Button
Yellow Button
Blue Button
Hi new to all this what arediseqc and usals and how will they improve signa .I have also lost freesat channels as has my friend
They wont improve your signal at all - usals & disecq are for motorised dishes or switching between 2 or more lnb's on a multi dish setup.
Which channels are you missing??
what arediseqc and usals and how will they improve signal
They won't. They are a way of using multiple LNBs or driving a steerable satellite dish so you can see signals from other satellites.
We need a bit more information but as a starter, have you had any strong winds that might have moved your dishes a bit?
EDIT
Damn, too slow
obeonek
fta, freesat
cork
Press
Menu
Setup
Red Button
Green Button
Yellow Button
Blue Button
Green Button
Yellow Button
Blue Button
New to allthese terms canyou explain what diseqc settings and usals
mean and are used for please even better is there some where one can learn the basics in layman terms thanks
First of all - have you solved your problem and found your channels?
Second - unless you have a satellite dish with a motor to move it around OR more than one LNB or satellite dish then these settings are COMPLETELY useless to you.
Try these links for basic information
_http://en.wikipedia.org/wiki/DiSEqC
_http://en.wikipedia.org/wiki/Universal_Satellites_Automatic_Location_System
obeonek
fta, freesat
cork
Channels lost multi screen, bbc news, cnn,euro news, also sky news on non freesat
Priceless
New to satelites so need advice. Have purchased Humax Foxsat HDR but need a suitable dish
Thatcham, Berkshire, UK
Thanks to all for the info! Looks like I need go and buy a dish and motor and then start the real fun!
dcs
80cm motorised with humax
scotland
To follow up on the last question please. Does the Humax HDR 1000S have the same hidden menu option for control of a motorised satellite that Foxsat has please ?
I have found a hidden menu for CRID but not for motorised settings.
Thank you
david
mouse3
1.2 offset,1.2 simetric ,0.9 offset.
Transilvania
Hi,guys,want to now if humax foxsat hdr receiver work in C band.Thanks.
There are far* better receivers to use for C-band than a Freesat receiver which is basically hobbled to use on the 28E Ku band service
(*) Like virtually anything else!
