a33
Specialised Contributor
- Sep 24, 2009
- Age
- 63
XSAT410
Rebox RE-9000
- The Netherlands
Plenty of manuals here, I would say. Which one gives problems?
Edit: If you mean you can have good tracking of the arc while west from south, and have to adjust mount and dish settings to have good tracking of east from south, then your due south setting is off (and maybe more...!).
Best way of checking mount settings I believe is check every step of the setup:
- pole exactly plumb east/west-wise?
- rotation axis elevation set at correct (modified) angle?
- dish declination set at correct (modified) angle?
- setup outlined to due south exactly (while mount and dish aligned perfectly)?
greetz,
A33
This is rather cryptic. Could you elaborate, what you are doing/trying?i get to tune in the W or E but not both at the same time.
greetz,
A33
