sky digital card with a dreambox 7000?
2012
Dreambox DM7000S on a 1.2m fixed dish , Sky+HD on a 3M fixed dish , windows7, ubuntu 9.1 and many other toys.
Hi, Can I use my dreambox 7000 with a sky digital card? if so which cam do I need?
is there software to do the series link recording? :D
Tom
Yes you can, but as you don't have the full Sky EPG, you can't use the series link as far as I know. There are a couple of sticky threads regarding using the Sky white card in your Dreambox.
2012
Thanks but I couldnt find any sticky threads on this subject, can you point me to them? does this work with the current cards. thanks Tom
bitonw
www.bit4net.com
DM7000, DM500, 120cm dish 3 LNBs, Sky dish 1 LNB
West Sussex
you only need C C cam installed to get it working. i have this for years without any problems.
He's probably sorted now - this thread was started back in April :D
