Newbie Here Spanish nagra system help with something weird
V
Vanhoteen
Ferguson ts100, 100cm + Motor +LG4K TV
Spain
hi i am interested in nagra system and i love hackrf
I have a hacktv with a Spanish decoder and something strange happens if I put the menu decodes the audio but the image is impossible for me, I think the key is expired.
S
Szycha881
HotBird 13E, nc+ receiver
Poland
Only-audio decoding when infos are showned is normal in that black-OSD units (even when there are no VBI data)
You should use Cpt Jack's HackTV fork captainjack64/hacktv and use C+ Spain parameter in command line
--syster cesfa --systeraudio
:D
V
Vanhoteen
Spain
:D
hello I have tried the code but it recognizes it as a file to play video.
$ hacktv -f 551250000  -m b 47 -a video.mp4 --syster cesfa --systeraudio
plays encoded audio and video but then
 UUUUUUError opening file 'cesfa'
No such file or directory
my key says it has expired keys in 2005
S
Szycha881
Poland
Key expiration doesn't matter because it's free-access mode (at least it should be)
Try this:
hacktv -f 551250000 -m b -g 47 -a video.mp4 --syster cesfa --systeraudio
V
Vanhoteen
Spain
I will prepare a pic 16f84 I think it will be easier than with the key.
Модератор
Make sure you are using my fork and the latest version. It should not say 'cesfa not found'.
I know it works with C+ Spain key as @homercartman has it working. (no guarantee that yours will, though).
V
Vanhoteen
Spain
ok, solution uninstall the hacktv and install the new one, now everything works perfect.Thanks a lot
I find the topic of signs very interesting, even these old ones that awaken my nostalgia, I put a piece of information that I find curious.
the audio syster signal was based on the USSR signal for its communications with the Salyut 6 space station
Модератор
Yes, I remember reading about the Salyut audio. Very interesting.
Glad it works. Can you post a video of it working?
V
Vanhoteen
Spain
of course tomorrow I put the video (I have the children sleeping)
I will also show you something interesting about hardware.
V
Vanhoteen
Spain
Hello Captain Jack, here is the result, thank you very much
NEW VIDEO
Video
S
Szycha881
Poland
Nice to see another resurrected decoder and key :)
You can also try Discret11 on it (best sample rate is 10MHz). Command-line:
--d11 cesfa
Wonder if hidden cut&rotate also works on Spanish decoders...
Модератор
Nice. Love the 6310i on the wall!
To get less flickering when filming CRT TVs, try setting the frame-rate of your phone to 25fps. I believe 50fps would be OK too.
V
Vanhoteen
Spain
I show you a close-up photo is 7110, the phone they developed for the promotion of the matrix movie.
Модератор
Ah 7110...yes. 6310 didn't have a flip. I had one of those - kept running out of message space! Great phone though.
Virtually bullet proof, their weakness was corrosion on the battery contacts (in this country)
I'm sure I've got a pair of them here, possibly GSM, ready for the nuclear winter.
V
Vanhoteen
Spain
It has a lithium battery, with its original battery from 1999 with a capacity of 60% for its age, the battery worked a week when I went camping.
I have a nokia 5110 also
And motorola pagers I am sending them messages through the hackrf and a soft GNUradio
people have pictures of fruit
I have a gameboy a nokia and I am thinking of making one with original and non-original satellite cards (pic 16f84, funcard).
F
FC GD
TBS6983 Professional DVB-S2 Dual Tuner PCI-e Card, TBS6522 Multi-standard Dual Tuner PCI-e Card, EyeTV Netstream 4Sat, EyeTV Netstream 4Sat (refresh) and Netstream Sat, EyeTV Sat CI, Hybrid (2008, International), EyeTV Sat Free
SDR: RSP1, Adalm-Pluto
Antenna: SelfSat H50D2
Pay Tv: Mtel, Telia
Stockholm
