TM5402 Mk2 repair help
norad97
TM5402 Mk2
Berkshire UK
My TM5402 Mk2 has a fault on the aerial side, it has stopped sending out signal.
The satellite side is working fine, but the antenna side has stopped working, I suspect the tuner is faulty,
I would like to replace it, does anyone no where I can get a replacement??
I have good soldering skills so I can replace if I had one.
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
Have you tried technomate ?
You mean for RF output?
