Triple Dragon Power Supply Schematic
I needed a circuit diagram for the power supply section of the TD, but unhappily it's not available anywhere AFAIK. Even the guys on the official TD forum don't have one.
Only thing for it was to trace the existing circuitry on the board. I had a spare TD which had a PS which had suffered catastrophic failure - the chopper FET had shorted and taken with it the current mode controller IC, plus transistors and various diodes and resistors.
As it necessitated a rebuild, the opportunity arose to be able to (fairly) easily trace the wiring routes and component values with the damaged components removed.
Only the secondary circuitry is shown here; this may help in identifying vulnerable components, e.g electrolytics. I'm still drawing out the primary, which I will add later.
Having added the primary schematic (a little more time was needed to draw that one out :-doh2) I might as well stick them up as PDF files too -
A small note for purists - I showed the transformer in my original drawing as a steel-cored type - hardly the type to be seen in an SMPS :-rofl2
Now changed to ferrite cored.
R
runner
Triple-Dragon DBS-3000cncie 250gb HD
Digital H.H V-bracket Cryptic Motor
1m Orbital Dish
Birmingham
Hi Llew,
Need your advice as you practically know about everything about the Triple Dragon.
I have a DBS-3000cncie for some years. Its in the box now because I could not connect it to my router. I'm not very good with computers & networking.
I recently bought a new wireless router and in the proccess of buying a new HD Tv. There has been a lot of good Hd Satellite receivers on the market which requires no programming and auto updates by themselves - The Protek 9750HD and SpiderboxHD with Gift/Service, these seem to be hassle free with ease of use.
The Triple Dragon is a good quality SD receiver but seems to have lost the support it deserves, the hardware could have been much better. With you advice, shall I unbox my Triple Dragon again and have another go or buy a Hd receiver with less to do?
Regards, Runner
runner said:
Hi Llew,
Regards, Runner
Hi Runner, welcome to the forum.
I still use my TD as well as a Dreambox HD receiver. Despite looking a little retro regarding the Menu system, that's what makes it so easy to use - don't know about the other boxes you mention. I suppose it's a question of how 'up-to-date' you need the receiver to be - I have the last image that was available from TDMan, over a year ago, and it suits me fine, just needing updating with channel lists from Dreambox sites.
If an HD box is of prime importance, there's plenty to choose from, but I can't fault the picture quality of my TD.
R
runner
1m Orbital Dish
Birmingham
Thanks Llew for your advice,
I shall give the Triple Dragon another go from the beginning with more time and patience.
Regards, Runner.
Good move, Runner. Should be enough info here, howto pdfs etc.
If you get stuck, just ask.
