Advice Needed Two dish placement
stel883_
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18" Superjack 3618, Moteck Vbox2, IBU Quad" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single" "Amiko SHD-8360, Edision Primo IP S2, Axas E4HD Combo, Edision OS Mini 4k" "Tivusat Gold Card - Oscam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi again, we re-positioned the stand alone mount, for the 1.2 meter dish further east and cleared 34.5 west, that's the polarmount's limit for the west side of the arc. Also, cleared 70 east and polarmount did 75 east with room for a little more. I calculated 58 degrees on each side, so total 116 degrees arc coverage. One of the anchor screws needs some cement or adhesive coz' of looseness of the cemented rooftop. And lastly vbox2 & actuator were taken to be checked, for the er2 error not counting pulses :(
There is still some blockage from tall tree, now at 5 & 7 & 8 west.
stel883_
stel883_
Vátika, Greece
Here are some pics, i have tied the dish with some thin rope at the east limit. Also, last pic shows where cement has broken.
For that breakage, I would suggest an epoxy-loaded grout (if you can get some) - sticks like sh1t to a blanket!
If you can't get that, then add a decent amount of PVA liquid to the cement as that should stick nearly as well.
OTOH, before doing anything, I think you should try to take a close look through the breakage to see what caused it in the first place as there might damage to the roofing (??) underneath - in which case, that might get worse over time due to the extra weight of the dish and mount on it. If that looks possible, then move the whole setup somewhere else!
stel883_
stel883_
Vátika, Greece
I'm planning on fixing the whole roof in the future, breaking off all the loose cemented areas, re-cementing them and pouring sealer on top. The cause is the balcony steel rods rusted and expanding :(
When you do that. I'd still add the PVA liquid as it also acts to "waterproof" the cement - so should be a "double win".
And you'll probably need to replace the rusted steel reinforcing rods and join them to what's left of the "still-solid" existing ones - might need to welded, and then given coat of rust-prevention treatment to stop the same thing happening again.
stel883_
stel883_
Vátika, Greece
Update: Vbox2 was tested on another motorized system and still gives er2 error, so sent it back to supplier, i'm waiting for the outcome.
